Fuel Pump replacement for 4AGZE
Posted: Sun Mar 01, 2020 5:06 am
Hi all, I am going to replace the original fuel pump for the 4AGZE engine.
How should I find the correct LPH for my engine. The engine is stock except with a bigger pulley.
How to ensure the correct amount of fuel is injected into the engine after changing a bigger pump?
Do I also need to install a adjustable fuel regulator and AFR gauge to work togwlether with the new pump?
I see from many topics pointed the direction for bigger fuel pump but not one telling much on the adjustment.
Thanks a lot.
Thanks a lot.
