OST-049: 1G-GTE
OST-049: 1G-GTE
Postby oldeskewltoy » Fri May 18, 2018 12:09 pm
Well, I've worked a 5MG, and 7MGTE, now it's time to work their little brother, a 1G-GTE
The 1G-GTE is a 2 liter inline 6 cylinder that made 210hp. The 1G-GTE uses a 75mm bore, and 75mm stroke, as a comparison, the 4AG uses 81mm bore and 77mm stroke.
Anyone see anything??
more to come....... :D
Re: OST-049: 1G-GTE
Postby oldeskewltoy » Sat May 26, 2018 4:43 pm
Did you see what the arrows were pointing at? Originally I was worried... that discolor, and shape are common when looking at burnt valves......... but they cleaned up ;)
Valve sizes: 28mm intake, 23.5mm exhaust. As comparison, the 4AGE uses 30.5mm intake valves, and 25.5mm exhaust valves. Very cute... the 1G-GTE intake valves have both the Yamaha logo, and the "teq" logo, while the exhaust valves just have the "teq" logo.
The head is now back from the shop, it's clean, and pressure checks ok.
One more step before I begin work...... a new tool
A new flowbench bore adapter... This one 77mm
more to come...... :D
Re: OST-049: 1G-GTE
Postby oldeskewltoy » Fri Jun 01, 2018 7:28 am
got it on the bench......
Re: OST-049: 1G-GTE
Postby oldeskewltoy » Fri Jun 01, 2018 8:14 am
progress(left chamber).......... bowls and seats now @ 85% of valve diameter
more to come....
Re: OST-049: 1G-GTE
Postby oldeskewltoy » Wed Jun 13, 2018 4:31 pm
got the head back from the machine shop...
3 down.... 3 to go
more to come..... :D
Re: OST-049: 1G-GTE
Postby oldeskewltoy » Sat Jun 16, 2018 7:59 pm
Before.... and after - intake side.
The 1G-GTE uses valves that are about 5mm shorter then 4AG valves... yet the 1G-GTE valve guides are HUGE in comparison. The 1G guides measure out to 45.75mm(1.8"), the 4AG guides 40.65mm(1.6"). so the valve is 5mm shorter, and yet the guide is 5mm longer - so I shortened the guides.
more to come........ :D
Re: OST-049: 1G-GTE
Postby oldeskewltoy » Sat Jun 23, 2018 5:31 pm
oldeskewltoy wrote:Before.... and after - intake side.
This time the exhaust side.......
more to come.... :D
Re: OST-049: 1G-GTE
Postby oldeskewltoy » Sun Jun 24, 2018 12:27 pm
and to try to explain the exhaust ports...... (the odd shape inside...)
Re: OST-049: 1G-GTE
Postby oldeskewltoy » Tue Jun 26, 2018 11:05 am
I had the stock cams "mapped" by Web camshaft....
What do they tell you??
Re: OST-049: 1G-GTE
Postby oldeskewltoy » Wed Jun 27, 2018 8:16 am
oldeskewltoy wrote:I had the stock cams "mapped" by Web camshaft....
Well.... let me tell you what I see.
1) split durations - exhaust longer - LIKELY to compensate for added valve clearance on exhaust side - but not limited to that reason
2) Beginning with the intake cam, the overall duration is 261, while duration @ .050" is 194, the exhaust cam is 270/199. As a comparison - stock early 4AG cams are 240 overall, and 204 @ .050". Observation - The 1G-GTE cams have a VERY mild/gradual ramp.
Now to fit that in with what I found on the flowbench. The stock intake ports began to go flat @ .250" lift, and went total flat by .300". The stock exhaust ports went totally flat by .250" lift.
The newly ported head changes the heads flow. Now the intake port flows out to .350" lift, while the exhaust port now flows out to .325" before going flat. With the head changes, a new set of cams are being built for this 1G-GTE.......
Return to “TECH: Inline 6's and V8's (JZ, G, UZ etc...) and Big Sedans”
