Just while I am thinking about it, and since it is semi-relevant to this thread.
In this part of the world there was a long tradition of 6-hour endurance races for
production cars. Basically, competitors would take a showroom stock production
car and prep it to go hard out for a full 6 hours of racing on a road circuit.
Even with 12 months worth of preparation, it was interesting to see that a lot
of cars could not last out the 6 hours. Overheated engines, failed gearboxes and
diffs, electrical and fuel problems etc would take down quite a few good quality
cars before the 6 hours was completed. Note that engine modifications for more
power were not permitted... these cars ran stock power levels.
So why is it you might ask, that a car in perfect mechanical condition could not
last for 6 hours of high speed running ? And the answer is that production cars
are not designed to be run flat out continuously. In the real world that is simply
not possible with other traffic, speed restrictions and less than ideal roads. So
the manufacturers build a family car that can go hard out for short bursts, but it
is not built to be capable of continuous operation at maximum power.
Modifying the engine for more power will simply cause the car to crap out sooner
UNLESS all the mechanical components are uprated to handle the extra load. If
you want a car with 250hp, far better to start with a car that had close to 250hp
when it left the factory. Cheaper and safer than trying to squeeze 250hp out of
a car that struggled to make 100whp stock.
If only I could have figured that out before I started messing with Corollas
