Fuel line question
Posted: Tue Sep 04, 2018 6:31 am
by tlea
Hi again. I am trying to figure out the fuel line configuration for the 20 V Does the return to the fuel tank come off of the intake? If so where is it located. I am assuming the inlet is the larger banjo fitting at the rear of the engine Also what psi do the systems like to run at?
Thanks in advance
Re: Fuel line question
Posted: Wed Sep 05, 2018 2:48 pm
by jdm86gtz
The fuel return is at the front of the engine from the fuel pressure regulator (FPR) there's a short hose about 3 inches long between the FPR and the steel pipework under the throttles. The fuel feed is at the back of the engine through a banjo fitting.
The manual states there should be 34-40 psi of fuel pressure without the vacuum reference hose connected.
Posted: Wed Sep 05, 2018 6:17 pm
by tlea
So the regulator is after the fuel goes to intake? Can I use an aftermarket adjustable regulator?
Posted: Thu Sep 06, 2018 1:25 pm
by jdm86gtz
You have an internal fuel rail in the inlet manifold and the fuel travels from the rear to the front and out through the regulator.
Tom's did a bolt on adjustable FPR but very rare these days, you may be able to convert the original regulator with a B&M kit or use an adapter and remote mount an AFPR.
But do you even need more fuel pressure?
Posted: Fri Sep 07, 2018 8:25 am
by tlea
No I don’t need more pressure but this is going in a non Toyota platform. I’m adopting the tank to an in-line filter and didn’t know how it would work with the 20 V regulator. So on the original 20 v set up the pump pushes full pressure from the tank and isn’t regulated till after it goes through the intake manifold?
Posted: Sat Sep 08, 2018 3:58 am
by jdm86gtz
Yeah, high pressure fuel on 1 side of the regulator and low pressure on the other. The regulator sets the fuel pressure.
The return side has a rubber hose with a simple spring type clip on it.
