Someone from our Club4AG Facebook Group Page requested the info about the ARP head stud. Even thought this dude in/lives Japan ( which tickles my humor ).
Well here are the info regarding the Dizzy hitting the head studs. I did my rebuild using ARP head studs. I hope you do what I did.
Shaving the dizzy with the least amount of metal taken off! Like shown in the pics I did.
The reason why I shave off the dizzy because of the risk factor of the ARP Head studs "experience more stress" than the dizzy.
Plus you would want to re torque your head studs later on during break-in.
I assume you guys correctly install your ARP head studs to the TEEEEEEEEEEEE so that all the head studs are evenly installed to EVEN level.
CLEAN THOSE THREADS HOLES LIKE A MADE MAN ON THE 4AGE ENGINE BLOCK!
ARP Head Studs for 4AGE 16V info
- Rogue-AE95
Re: ARP Head Studs for 4AGE 16V info
I noticed the smallport dizzy has a longer end piece. Could I just cut off a small section, then grind down the rounded bit like shown above?
And on a related note, how do you remove the smallport dizzy's gear to change out the bearing & seals? There's no pin going through the smallport one.
i still havnt had a chance to call arp concerning this issue, hopefully i can get my lazy ass out of bed early enough tomorrow. my distributor is from a large port. you should have a roll pin in both. ill attach diagrams below, the small port is the first pic and the second is the large port.
- Rogue-AE95
Would it make a difference if my smallport distributor came out of a Geo Prizm GSi instead of a Corolla GT-S? There is definitely no pin in my dizzy.
I suppose, since I'm going standalone, that I could just use a bigport dizzy instead. But finding one with decent, uncracked wires...
Here's a pic of the Geo Prizm smallport dizzy:
Unrelated side question. Is it a terrible idea to completely disassemble a dizzy? As in removing the stuff inside that says "don't remove" in bold letters?
I also Used ARP head studs
I took some white out and painted the end of the dist. so I could see just where the interference was
Davegt27 Code One Racing
Rogue-AE95 wrote:Unrelated side question. Is it a terrible idea to completely disassemble a dizzy? As in removing the stuff inside that says "don't remove" in bold letters?
Yea it might be. But to swap internals over, hey who hasnt? I think theres a proceedure to set the pickup coil projection (or signal generator?dangit..correct me if I'm wrong) to the signal rotor,which is in the RM so I'd look that up first
Don't you hate it when you see "don't remove, don't look, don't open till xmas" ...the temptation is unbearable
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
87 GTS Coupe
just got off the phone with ARP, the technician stated there will be no problem removing the required material off the top of the stud using a cut off wheel using 2 nuts and run them down cut off the required material then remove the nuts chasing the threads. they give this recommendation to ford and chevy guys also. they attribute this to inconsistencies in the block and/or head. i think i will go with this approach versus grinding the shaft and possibly messing up the rotating mass of the distributor.
anthony55901 wrote:...possibly messing up the rotating mass of the distributor.
Not a chance in hell!
- Rogue-AE95
KonaTrueno723 wrote:Rogue-AE95 wrote:Unrelated side question. Is it a terrible idea to completely disassemble a dizzy? As in removing the stuff inside that says "don't remove" in bold letters?
OK, thanks. I had removed all the internals from one of my bigport dizzies, because it was going to become an adapter to mount a Honda dizzy (using a chipped Honda ECU as poor man's EMS). Now I'm thinking about rebuilding it (new bearings etc) for use on my 4A-GTE build, and maybe even powdercoat the housing before doing so. Plus it has the removable bigport gear on the end, so I could maybe swap the smallport dizzy internals into it...
