is this possible, 4ac oil pump on a 4age block?
is it possible to use a 4-ac engine oil pump on a 4age block? I really hate how it's always a pain to take off the timing gear off 4age engines because of the way toyota decided to design the 4age oil pump.
Last edited by Takumi-Fujiwara on Wed Nov 27, 2013 11:51 pm, edited 2 times in total.
Re: is this possible, 4ac fuel pump on a 4age block?
AFAIK the 4AC fuel pump is a low pressure mechanical pump mounted on the
rear of the head and driven off the single camshaft. There is zero chance of
mounting it on a 4AGE. The 4AGE fuel pump is a high pressure electric pump
mounted in the fuel tank.
I really think you should not post after you have been smoking. Or if you must,
send me some of dat sh*t so I can understand your question
I meant to write oil pump lol
Re: is this possible, 4ac oil pump on a 4age block?
The 4ac and the 4age use the same type oil pump that mounts behind the crank pulley/lower timing belt sprocket.
Would you be able to take a picture of the part you are asking about?
weird. maybe the 4ac has an aftermarket oil pump because it is different from what my 4age
Takumi-Fujiwara wrote:weird. maybe the 4ac has an aftermarket oil pump because it is different from what my 4age
depending on lower timing cover differences... the external may be slightly different. I ran into this when I tried the G oil pump and then tried to fit the "F" timing cover... it doesn't completely line up....
hi there i dont know if this it works on you but take a look on this oil pump its toga --not toda -- its american you know i have this on my 4age corolla its stong enougth http://www.importperformanceparts.net/i ... oyota.html
