yearly Garage Sale...north NJ
morgan
Postby morgan » Fri Aug 02, 2013 12:39 pm
This thread was started on 8/2/2013^^^ so there's a chance that I don't have this stuff any more...please let this thread DIE
its that time again, here's my list of stuff not needed.
I ONLY HAVE WHAT YOU SEE, these are all of my parts for sale
I DO NOT WANT TO DEAL WITH INTERNATIONAL SHIPPING, please dont ask, sorry.
Parts located in North East NJ, willing to meet up, have you stop by, or ship.
Prices as listed, do not include shipping/paypal fees, unless noted.
If its "FREE" then thats what it is for the part. please dont be greedy and ask for a bunch off free stuff and nothing else.
Parts1
1. SOLD
2. SOLD
3. SOLD
4. 4age 20v motor/trans brace-free
5. SOLD
6. SOLD
7. used ae86 front brake lines-free
8. SOLD
9. SOLD
10. ae86 brake master cylinder res. w/cap-free
*not #’ed-ae86 antenna bracket-free
11. SOLD
12. fwd 4age rear head outlet-$5
13. door latch/loops-$5
14. ae86 rear drivers sidewheel well guard(3 pieces)-$2.50/each
15. fwd 4age rear head outlet-$5
Parts2
16. door opener cups/pair(painted satin black)-$5
17-20. misc. door opener cups-$2.50/pair
21. ae86 seat belt retractor bezel/pair(painted black)-$2.50
22. ae86 seat belt retractor bezel(oem bluish grey)-free
23. SOLD
24. SOLD
25. single window crank(oem black)-$5
26. SOLD
27. ae86 oil pressure sensor(reads about one bar lower than it really is on gauge)-$5
28. fwd(aw11 mr2?) oil pressure sensor-$2.50
29. 4age 20v oil pressure sensor(2 pieces)-$2.50/each
30. ae86 4age temp sensor for cluster-$5
31. SOLD
32. SOLD
33. SOLD
34. 4age 20v ECU water temp sensor-$5 (1 w/pigtail=SOLD)
35. wheel caps(62mm diameter hole)-$15/set of 4 bnib
36. SOLD
37. SOLD
38. SOLD
39. ae86 bluish grey rear seat buttons-$2.50/set
40. ae86 hatch rear blue hook-free
41. 4age 20v valve cover ventilation valve-$10
42. large pocket cover on cluster surround(painted white)-free
43. ae86 gauge cluster surround lights(above light & wiper switches)-$2.50/set
44. ae86 fuel door lock/popper-$10
45. fwd 4age crank pulley bolt-free
46. ae92 sun visor mount-free
47. 4runner/ae86 sunvisor mount(needed to use ae92 visors in ae86)-$5/set
48. SOLD
49. SOLD
50. “Toyota” emblem-$5
51. SOLD
52. SOLD
53. SOLD
Parts 3
54. ae86 sr5 starter(2 pieces)-$20/each
55. ae86 clutch slave(no push rod)-$5
56. ae86 front wheel bearing grease caps-$2.50/set
57. SOLD
58. SOLD
59. SOLD
60. ae86 hatch “C” pillar(Drivers side-no rust)-$15
61. ae86 hatch “C” pillar(Passengers side-no rust)-$15
62. ae86 rear bump stop set-$10
63. SOLD
64. ae86 sr5 evap purge tank and solenoid-$5
65. SOLD
Parts4
66. SOLD
67. ae86 sr5 front sway bar-free
68. SOLD
69. ae86 hood latch/release with support-$15
70. 4age 20v injector wire cover-$5
71. fwd 4age(aw11 mr2) throttle body-$5
72. ae86 side moulding end pieces(fenders-thick mouldings)-$5/set
73. ae86 driveshaft center bearing shield-$5
74. ae86 hood hinges-$10
75. SOLD
76. SOLD
77. exhaust flange(303 s.s. w/3” opening)-$5
78. SOLD
79. ae86 front ashtray(burgundy)-free
80. SOLD
81. AE72 hatchback door opener bezel(1983)-$5
82. 1 ae86 passengers side door hinge(no wobble-need to confirm top or bottom)-$5
83. modded coolant line for 20v(ae86 heater core to ae86 rear housing pump-$5
84. SOLD
85. SOLD
86. ae86 hatch lid lock-$10
87. SOLD
88. SOLD
89. AE72 hatchback rear washer fluid bottle-clean/no cracks(1983)-$15
90. SOLD
Parts5
91. ae86 hatch wiper motor-$15
92. ae86 a/c electrical idle up valve-$10
93. 4age fwd aw11 mr2 ERG valve-$5
94. media blasted ae86 drivers side motor to trans bracket-$5/dirty bracket=SOLD
95. SOLD
96. fwd 20v lower alternator bracket-free
97. fwd 4age water pump pulley-$5
98. SOLD
99. ae86 hatch rear window washer pump-$2.50
100. SOLD
101. ae86 windshield cowl vent-$2.50
102. SOLD
103. SOLD
104. SOLD
Part7
105. ae86 lower door sill gasket(3 pieces)-$2.50 each
106. SOLD
107. SOLD
Parts8
108. ae86 lower door trim piece(set-1 piece was bent)-free
109. ae86 lower door trim piece(set-some overspray on them)-free
110. ae86 coupe drivers rear window trim(missing lower piece)-$5
Parts9
111. ae86 interior vertical door trim at rear panels(painted black)-$5/set
112. ae86 interior vertical door trim at rear panels(oem black)-$10/set
113. SOLD
114. SOLD
115. ae86 passengers kick panel(faded oem blue)-$5
116. ae86 interior pass. side door/carpet trim(oem blue)-$5 *drivers side SOLD*
117. ae86 coupe rear headliner trim(oem black)-$10
118. SOLD
Parts10
119. ae86 interior “B” pillar trim-drivers side(painted black)-$5
120. ae86 interior “B” pillar trim-drivers side(oem black)-$10
121. Levoc shift knob-$5
122. ae86 seat belt sheath(oem black)-$2.50
123. ae86 drivers side female seat belt connector(oem black)-$5
124. SOLD
125. SOLD
126. SOLD
127. ae86 bnib oem black clock bezels(2 pieces)-$20/each shipped
Parts11
128. ae86 power mirror harness-$5
129. ae86 window track w/rubber(think its drivers front)-free
130. ae86 window track w/rubber(think its passengers rear)-free
131. ae86 window track-2 pieces w/rubber(think theyre drivers rear)-free
132. SOLD
133. SOLD
134. ae86 door stop/brace-free
135. ae86 outer door trim-free
136. SOLD
137. SOLD
138. SOLD
139. ae86 hatch rear interior panel brace/set-$5
140. ae86 drivers window regulator(no play in crank shaft)-$40
141. ae86 outer door trim-free
142. SOLD
ae101 steering wheel-$60 shipped
^back up after buyer couldnt figure out how to mount a steering wheel and complained it didnt fit. pictures prove otherwise...
ae86 exhaust heat shield set-$15
mk3 supra intermediate shaft-SOLD
ae86 hatch rear windows-$20/side
T3 ITB splash guard=SOLD
my repro ae86 battery tie-downs-$40 shipped/each
***comes with what you see in 1st pic: tie-down, J-hook(oem from dealer), washer & nut for hook***
FITS OEM SIZED BATTERY ONLY
no time to make these anymore, these are the last 5 for a while. lifes too busy...
***SOLD OUT***
ae86 doors complete with what you see(no hinges or regulators-glass is included however). started body work on passengers side-$100/set obo
drivers has little crease near outer handle and chip in mirror housing
if you dont like what you see, please move on and keep negative comments to yourself.
thanks for looking.
My turd of an 86
20v swapped 86 write-up
assassin10000
Re: yearly Garage Sale...north NJ
Postby assassin10000 » Fri Aug 02, 2013 1:27 pm
I may want 6 & 59. What's missing off 6?
Andrew
ga_goosh
Postby ga_goosh » Fri Aug 02, 2013 1:33 pm
Ill take 36, 58, 100, 84, 57, 85
I <3 my AE86
4AG Manual
AE86 FSM
morgan
Postby morgan » Fri Aug 02, 2013 1:36 pm
andrew-amplifier and other odds and ends. PM my your email and ill send over a bunch of pics.
Sean-you got it.
leaving work right now, ill PM you both in a bit once the kiddies are settled in for the night.
thanks
My turd of an 86
TORPARTS
Postby TORPARTS » Fri Aug 02, 2013 7:30 pm
great seller!
http://www.torparts.com
GEOVA TRD
Postby GEOVA TRD » Fri Aug 02, 2013 9:42 pm
Great Stuff....Unbeatable prices!!
SlideSexy
Postby SlideSexy » Fri Aug 02, 2013 9:48 pm
#9 doesnt have a price on them and id like them. Whats your price?
ANYONE CAN BUY A NEW CAR. IT TAKES A TRUE ENTHUSIAST
TO BREATHE LIFE INTO AN OLDER ONE.
Phoenix Down
Postby Phoenix Down » Fri Aug 02, 2013 10:08 pm
1. ae86 heater box w/modded core inlet/outlets-$10
2. ae86 fan-$5
5. ae86 interior insulation(behind ecu & junction boxes)-free
Will take all of them! does the heater box have a core?
Yay, Restoring...
iamjapanman
Postby iamjapanman » Sat Aug 03, 2013 12:28 am
Can I get a bigger picture of 33 (20v fan switch) sent to my pm inbox?
Also do you have a connector that connects to 33 (20v fan switch)?
morgan
Postby morgan » Sat Aug 03, 2013 5:47 am
PM'ed everyone
My turd of an 86
kiwi
Postby kiwi » Sat Aug 03, 2013 8:52 am
Great listing.
I will take: 88 (just want to check, the rail has the fastener for the fuel line (round screw type thing) coming into rail), 78, 51, 53, and 48.
Oh, I'm also looking for a T50 shifter and exhaust manifold, and or header.
Thanks,
Mike
morgan
Postby morgan » Sat Aug 03, 2013 11:39 am
Kiwi-i dont think the rail has the banjo bolt, i think thats what youre refering to. Might have one tho that fits from a 20v
My turd of an 86
socal1jzsupra
Postby socal1jzsupra » Sat Aug 03, 2013 12:39 pm
just wondering do you have rear driver side brake caliper for gts? if so im interested and how much to get shipped to 92262?
morgan
Postby morgan » Sat Aug 03, 2013 5:10 pm
What you see is what i got
My turd of an 86
riddleyo
Postby riddleyo » Sat Aug 03, 2013 8:54 pm
Wow, awesome listing. I'd like to get the following, but I cannot PM yet. Can I get a shipping quote to 45371 emailed to RIDDLEYO(at)GMAIL(dot)COM:
If still available: 6. ae86 a/c condenser box(some parts missing)-free-PENDING
34. 4age 20v ECU water temp sensors(pigtail please)-$5
2x - 105. ae86 lower door sill gasket -$2.50 each ($5)
114. ae86 passengers kick panel(painted black)-$5
Thank you.
hachi808
Postby hachi808 » Sun Aug 04, 2013 5:26 am
I'll take 124
my email is sikplants@hotmail.com
morgan
Postby morgan » Sun Aug 04, 2013 6:23 am
Emailed you both^
My turd of an 86
tak209
Postby tak209 » Sun Aug 04, 2013 9:57 pm
ill take part 88 let me know what shipping is to 95242. also does that one have the fuel feed line attached but cut? i also need a fuel feed line i was looking and idk if there was one.
burrito86
Postby burrito86 » Sun Aug 04, 2013 10:59 pm
how much for the heater core shipped to 92505 ca?
morgan
Postby morgan » Mon Aug 05, 2013 5:52 am
sorry burrito, list updated, that part is sold.
My turd of an 86
tak209
Postby tak209 » Mon Aug 05, 2013 5:22 pm
hey morgan i sent you a pm and posted i was interested in part #88 dont forget about me! lol =P
morgan
Postby morgan » Mon Aug 05, 2013 5:58 pm
PM'ed ya.
Everyone who has paypaled me, parts will be out in a few days. As soon as i get to the post office i will have tracking. Thanks!
My turd of an 86
tak209
Postby tak209 » Mon Aug 05, 2013 6:33 pm
payment sent =)
part 88 is mine =))) bigport fuel rail with fpr and pulse dampener.
thanks man!
datsr5
Postby datsr5 » Tue Aug 06, 2013 1:24 pm
ill take 51 52 and 53.
text 651-302-2046
Sam
morgan
Postby morgan » Tue Aug 06, 2013 8:56 pm
Datsr5-Texted you a few hours ago, havent heard back
My turd of an 86
TORPARTS
Postby TORPARTS » Wed Aug 07, 2013 11:22 am
legit seller; honest and dependable.
Duma approved!
HACHIFOX
Postby HACHIFOX » Fri Aug 09, 2013 11:19 pm
Ill take a number 26 the blue connector 2 wire resistor willing to pay shipping to 94560 ca
Ita Racer
Postby Ita Racer » Sat Aug 10, 2013 8:12 am
If items
37,71', and AE86 exhaust heat shield still for sale
I have PayPal account a ready to buy.
Please state total price including shipping.
I will pay ASAP
85 AE86 Race Car
91 Supra non turbo
96 Celica convertible
2006 4 Runner
Ita Racer
Postby Ita Racer » Sat Aug 10, 2013 8:17 am
Sorry zip code 33611
85 AE86 Race Car
91 Supra non turbo
2006 4 Runner
morgan
Postby morgan » Mon Aug 12, 2013 10:00 am
PM'ed you both^
My turd of an 86
