Short stroke strut service
seymour86
Postby seymour86 » Mon Sep 16, 2013 8:34 am
Custom short stroke set ups have long been the preferred setup for AE86 enthusiasts due to the fact that you have the choice to mix and match dampers and spring rates to get the set up that will work best for your application. I am offering the service of modifying your OEM strut casings in order to run a short stroke/coilover setup. All welds are TIG welded by hand. Located in the Los Angeles area, shipping available at customers expense.
Contact through e-mail for fastest response breezefabrication@gmail.com
Price structure breaks down as follows
• $160 - Short stroke conversion - Strut casings shortened 40mm unless otherwise specified, stock spring perch cut off and new spring perch to support coil over welded on.
• $50 - Disassembly – Removal of stock spring, upper spring seat, damper and oil disposal.
• $50 - Cleaning and stripping – Removal of all the gunk/oils on the casings and stripping of the paint.
• $50 - Paint – Primer coat and 3 coats of high temp low gloss black.
• $20-Aluminum spacers -Pair
• $80 –Assembly (pair) – Complete assembly of high hats, strut insert (aluminum spacer included) and coil over sleeve. You must supply parts for assembly.
******POWDER COATING is now available*******
seymour86
Re: Short stroke strut service
Postby seymour86 » Wed Sep 18, 2013 3:32 pm
Just bought a new torch, Itching to burn some rod.
seymour86
Postby seymour86 » Sat Sep 21, 2013 10:21 am
Emails replied
seymour86
Postby seymour86 » Thu Sep 26, 2013 12:36 pm
bump
87Coupe_de_Ville
Postby 87Coupe_de_Ville » Fri Sep 27, 2013 3:03 am
Buy his service!
1st place at Toyotafest 2012 and 2nd place at JCCS 2012.
seymour86
Postby seymour86 » Thu Oct 03, 2013 7:40 am
Bump
Thanks Luis! you make it out to JCCS this year?
seymour86
Postby seymour86 » Tue Oct 08, 2013 11:37 am
Bump
seymour86
Postby seymour86 » Sun Oct 13, 2013 5:45 pm
Emails replied.
seymour86
Postby seymour86 » Fri Oct 18, 2013 8:41 am
end of the week bump.
chohdog
Postby chohdog » Fri Oct 18, 2013 11:25 am
At least from the photos attached, this guy's work looks fantastic. For those of you who think that the only thing available are the Chinese brands, this guy can get you started on a real nice coilover system. Plus, you can service/choose the shock yourself! Yet another option on great AE86 suspension.
Stock4AG
Postby Stock4AG » Fri Oct 18, 2013 2:14 pm
Looks great!
Do you have some ideas how I can check my hub/spindle for good health when I am finding a core to use?
seymour86
Postby seymour86 » Mon Oct 21, 2013 9:45 am
chohdog wrote:At least from the photos attached, this guy's work looks fantastic. For those of you who think that the only thing available are the Chinese brands, this guy can get you started on a real nice coilover system. Plus, you can service/choose the shock yourself! Yet another option on great AE86 suspension.
Thank you sir. You've been in the game for a long while and you know your stuff from what I have read in your posts over the years,so those word mean a lot to me.
Stock4AG wrote:Looks great!
I look where the top of the spindle base and tube meet for chipped paint or stretched metal. Usually the first thing to bend on the front suspension set up is the steering knuckles, So when I pull cores from the junk yards I look at those before I even touch them with a wrench. Make sure strut inserts fit in to the casing. If the tubing is bent the inserts or 1.75" tubing will have a little more friction going in or will not go in at all. Also make sure that the threads on the top that the gland nut screws into is good.
seymour86
Postby seymour86 » Thu Oct 24, 2013 3:05 pm
bump
mikeyee
Postby mikeyee » Fri Oct 25, 2013 1:02 am
seymour86
Postby seymour86 » Wed Oct 30, 2013 9:00 am
Ha Ha kicking it old school
kendallspower
Postby kendallspower » Fri Nov 01, 2013 8:19 pm
Bump for a good seller. On time and professional.
seymour86
Postby seymour86 » Thu Nov 07, 2013 10:37 am
Thanks Kendall,It was nice meeting you and I look forward to seeing your car when it is all done.
seymour86
Postby seymour86 » Mon Nov 18, 2013 9:46 am
Monday bump
seymour86
Postby seymour86 » Mon Nov 25, 2013 12:10 am
bump
SidekickChuck
Postby SidekickChuck » Mon Nov 25, 2013 8:18 am
Beautiful welds
2001 Carbon Black e39 M5
seymour86
Postby seymour86 » Thu Nov 28, 2013 11:04 am
Thank you sir!
350nizmo
Postby 350nizmo » Wed Dec 04, 2013 11:00 am
sent you an email
1986 Toyota Corolla AE86 Apex GT RHD (Garage Queen)
2007 Honda Fit Sport (Daily)
auto8386
Postby auto8386 » Wed Dec 04, 2013 12:08 pm
Sent you an email regarding service. :)
-Edward
seymour86
Postby seymour86 » Fri Dec 06, 2013 4:41 am
E mails replied
jrae82
Postby jrae82 » Fri Dec 06, 2013 9:03 pm
Email sent
seymour86
Postby seymour86 » Sat Dec 28, 2013 6:57 pm
sorry guys, been super crazy at my day job. Looks to be super crazy up too the 31st of Dec.
seymour86
Postby seymour86 » Thu Jan 16, 2014 10:28 am
to the top
seymour86
Postby seymour86 » Tue Feb 04, 2014 10:15 pm
up and running!
comhosa
Postby comhosa » Wed Feb 05, 2014 7:47 am
pm sent
seymour86
Postby seymour86 » Mon Feb 17, 2014 12:09 am
Bump
