SoCal:4age rebuilded small port hi comp motor.
cerumo
Postby cerumo » Wed Jul 06, 2016 12:50 pm
Everything is new. NPR piston rings, ACL rod bearings, Asin oil pump. Resurfaced head with new valve guides and valve seals. Trd .08 head gasket. New Toyota front and rear main seals. Compression test 210 on all cylinders. Blue top cams for higher lift. Unseal oil pan. 2000 obo. Pick up only. 626 536 0066. Under
