WTB Sr5 to GTS Swap Parts
P3nnyw1se
Postby P3nnyw1se » Thu Aug 08, 2013 5:57 am
The title says it all. I'll list out what I need. Please post pictures with the items you have so I know what I'm looking at purchasing.
Thanks!
I'm building up a blue top engine so all parts should be for that although I already have most of the engine stuff I'll need.
I'll remove stuff from the list as I get it.
~List~
-RWD Water Outlet (One in the middle)
-JDM Kouki Front/Rear bumper mounting brackets
-GTS Gauge Cluster (Kouki)
Please don't reference your sales threads. Instead, let me know what you have that I need. This will save us both time.
mandm177
Re: WTB Sr5 to GTS Swap Parts
Postby mandm177 » Thu Aug 08, 2013 6:54 am
i have:
16v ECU and Engine Harness
GTS Speedo Gear
GTS Clutch Slave Cylinder (i think)
Brake Proportioning Valve
Aftermarket Ignition Coil and Igniter
email for pics and we can make a deal shipped to you.
mandm177@gmail.com
P3nnyw1se
Postby P3nnyw1se » Thu Aug 08, 2013 11:21 am
E-mail sent.
chunks
Postby chunks » Thu Aug 08, 2013 4:58 pm
I have most of te items u have listed. I can check for starter with heat shield
viewtopic.php?f=15&t=2207
Lmk
welcome to club4ag, aka the playa haters ball!
blackhmong85
Postby blackhmong85 » Thu Aug 08, 2013 6:43 pm
i have a complete gts zenki coupe in Sacramento, CA. lmk douathao85@yahoo.com
P3nnyw1se
Postby P3nnyw1se » Thu Aug 08, 2013 7:40 pm
The only issue is that I'm in Portland, haha. I'm running to the junkyard to see what I can pull so post what I'm using so I can adjust my list to fit!
Thanks everyone
chunks
Postby chunks » Thu Aug 08, 2013 10:02 pm
P3nnyw1se wrote:The only issue is that I'm in Portland, haha. I'm running to the junkyard to see what I can pull so post what I'm using so I can adjust my list to fit!
Thanks everyone
Good luck at the junkyard! Hope u find some stuff there
Joe4ag
Postby Joe4ag » Fri Aug 09, 2013 12:58 pm
I have one . sr5 to gts engine harness all ready for the swap, lmk
my text number: 914.848.one four five zero
P3nnyw1se
Postby P3nnyw1se » Wed Aug 14, 2013 3:06 pm
Update: It looks like I'll be getting a Big Port Bluetop so I'll need parts for that! I am worried about emissions stuff so whatever the car comes with stock will definitely help me out with that! I'll revise my list to fit more of what I need after I go pick it up!
Thanks again everyone.
woofsae86
Postby woofsae86 » Wed Aug 14, 2013 8:21 pm
P3nnyw1se wrote:Update: It looks like I'll be getting a Big Port Bluetop so I'll need parts for that! I am worried about emissions stuff so whatever the car comes with stock will definitely help me out with that! I'll revise my list to fit more of what I need after I go pick it up!
hey man i have the starter just need the heat shield i also have a ecu as well and a clean resurfaced mint flywheel let me know.
Can furries drift? The world may never know.
hachiroku ae86
Postby hachiroku ae86 » Wed Aug 14, 2013 8:36 pm
i have throttle cable,heat shield for starter,ignition coil, zenki engine harness with ecu. give me a txt for fast reply
Andrew Goodluck
email- hachitruenoae86@gmail.com
paypal- teenmob2@yahoo.com
cell- 909-697-7094
85coupe gtsr5 DDDM(dily driven drift missle)
98 ford f-150 DD blown up
P3nnyw1se
Postby P3nnyw1se » Wed Aug 14, 2013 10:14 pm
Let me take a look at what's coming with the engine and update from there!
Update: Finally able to send/reply. =)
SR5valves
Postby SR5valves » Thu Aug 15, 2013 8:18 pm
I need a flywheel a header and more maybe lets talk!!!!!!!!
please factor Factor in shipping to 02131
I cant dm OR PM anyone. . . .
Help?
woofsae86
Postby woofsae86 » Fri Aug 16, 2013 1:51 am
SR5valves wrote:I need a flywheel a header and more maybe lets talk!!!!!!!!
Help?
I have a flywheel
P3nnyw1se
Postby P3nnyw1se » Wed Aug 21, 2013 8:34 pm
Updated the list for what I'm looking for!
chickennugget
Postby chickennugget » Wed Aug 21, 2013 10:24 pm
clutch fork is the same, you dont need that.
P3nnyw1se
Postby P3nnyw1se » Thu Aug 22, 2013 12:45 am
chickennugget wrote:clutch fork is the same, you dont need that.
Oh, okay. Thank you!
woofsae86
Postby woofsae86 » Thu Aug 22, 2013 7:28 pm
hey man i still have that starter fuel rail and distrubutor if you need them hit me up for prices
P3nnyw1se
Postby P3nnyw1se » Fri Aug 23, 2013 1:34 am
woofsae86 wrote:hey man i still have that starter fuel rail and distrubutor if you need them hit me up for prices
Should have a PM from me now!
woofsae86
Postby woofsae86 » Sun Aug 25, 2013 6:05 pm
pm sent man let me know.
P3nnyw1se
Postby P3nnyw1se » Thu Aug 29, 2013 2:51 pm
Bump.
woofsae86
Postby woofsae86 » Thu Aug 29, 2013 11:59 pm
So are you giving me the run around or what did you want the parts after you had me do alk you asked for?
P3nnyw1se
Postby P3nnyw1se » Fri Aug 30, 2013 4:21 am
There are still parts that I need. I've been holding off on giving you an answer because I only want to have you send out a single shipment. I will be grabbing that starter from you, that I know for certain. I'll know by later today if I need the flywheel as well. I do appreciate that you took the time out of your day to do what I had asked and gather everything together.
P3nnyw1se
Postby P3nnyw1se » Thu Sep 19, 2013 4:03 pm
Bump.
P3nnyw1se
Postby P3nnyw1se » Wed Sep 25, 2013 2:49 pm
If it isn't on the list then I'm not looking for it. Thanks though!
1corollagts
Postby 1corollagts » Thu Sep 26, 2013 5:43 am
If you need I have stock header and down pipe no cat pm me will be the way to go.
Thanks.
P3nnyw1se
Postby P3nnyw1se » Thu Sep 26, 2013 1:55 pm
Replied.
P3nnyw1se
Postby P3nnyw1se » Mon Sep 30, 2013 4:13 pm
Bump
P3nnyw1se
Postby P3nnyw1se » Wed Oct 09, 2013 11:30 am
bump.
P3nnyw1se
Postby P3nnyw1se » Fri Aug 01, 2014 1:26 am
Bump after a long absence.
