Panhard bar / lateral bar DIY
marley4us
Postby marley4us » Tue Feb 26, 2013 4:54 pm
Got my parts in for my DIY Panhard bar / lateral done.
-2458K182 Ball Joint Rod End 3/4"-16 Lh (you just need one of these) $17.36 each Mcmaster.com
-2458K181 Ball Joint Rod End 3/4"-16 Rh (you see a trend starting ) $17.36 each Mcmaster.com
-6381K121 Bronze 3/4"-1/2" bushing (you'll just need one) $1.64 each Mcmaster.com
-91034134-27 (27")ALUM TUBE FOR 3/4" HEIMS (you'll need just one) $14.95 each Speedwaymotors.com
**These are your choice since it's just stuff you can get at your local hardware store and probably be cheaper but I'll list it up anyways
-1756047-LH JAM NUTS 3/4", STEEL 6/PACK (you just need one per side) $3.95 Speedwaymotors.com
-1756047-RH JAM NUTS 3/4", STEEL 6/PACK (ditto^^) $3.95 Speedwaymotors.com
I put the fitting on my drill and used some sand paper to get a perfect fit, took less then a min to do ;)
done
if you are using a celica suprarearend, you need to extend the bar another 1/2 inchs
I also finally finished the Panhard bar/ lateral bar. So the DIY set up does not fit a celica supra rearend just FYI for anyone else wanting to do this. I had to order a extra extension from K and H an local store here. K and H metals supply part number 917020044 3/4-16 alloy linkage adjuster Then grind down the metal around the bolt "it had a little ring around it" so I could get the bar to slip over it.
1994 4runner (The truck)
KonaTrueno723
Re: Panhard bar / lateral bar DIY
Postby KonaTrueno723 » Tue Feb 26, 2013 6:04 pm
marley4us..lateral bar is awesome! I got DIY gold link bars already & this is all thats missing & need to get done..Thnks for this post..
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
marley4us
Postby marley4us » Tue Feb 26, 2013 6:50 pm
can you post the DIY 4 link, I lost the the part number etc and could not re post that one.
frankist
Postby frankist » Tue Feb 26, 2013 9:30 pm
Is this bar adequate enough(rightsized) to adjust for a extremely lowered ae86? was the bar the right length? Thanks!
marley4us
Postby marley4us » Tue Feb 26, 2013 9:49 pm
its fully adjustable.
John H.
Postby John H. » Tue Feb 26, 2013 10:21 pm
Dayum Ian, you went animal on the DIY section! lol
All awesome and helpful though!
Thanks
-John
NC Panda
Postby NC Panda » Tue Feb 26, 2013 11:59 pm
+1 will be ordering these soon thank you. also, +1 on the 4link request... i could reallly use some
mase86
Postby mase86 » Mon Mar 04, 2013 4:27 pm
did the 4-link to the car early lasy your. Nice upgrade. As far as for the lat. bar for the celica/supra rear end sll i need is the linkage adjuster? If so i get this part that is in the link it's good to go.
http://www.ebay.com/itm/QA1-AS12-12-Chr ... 1d&vxp=mtr
mase86
Postby mase86 » Wed Mar 20, 2013 4:50 am
If your doing this for a celica/supra rear end. Note the ebay link i posted above. instead of (1) LH and (1) RH Ball joint rod end you will need (2) RH Ball joint rod ends due to the the pitch of the adjuster. I recieved my parts and i'm waiting on a RH one right now. The bar is stout and worth the time to get on your own to put together. The pics marley posted don't do the bar justice on how nice the bar is. I'll post some pics here later
mase86
Postby mase86 » Sun Mar 24, 2013 2:10 pm
So everything is put together and just need to install on the car. Here is the difference in dia../thinkness of stock bar compared to the aftermarket one. Just remember if you get the adjuster you will need (2) RH ball joint rod ends.
Here is a close up of the joint ends
Pidge526
Postby Pidge526 » Sat Apr 13, 2013 10:57 pm
I was just curious as you used the regular zinc-plated steel vs. aluminum or stainless (which cost 5x as much) how are they doing against corrosion? i'm just curious how these would hold up or how they are holding up to road debris, salt, dirt, sand, etc.? I'm interested in making one myself versus the $150+ price tags on other products,but just curious on your expectancy or longevity of the ball joints themselves.
Thanks
mase86
Postby mase86 » Sat Apr 20, 2013 10:03 pm
Haven't used it yet due to the fact I'm building this car as a track car. I'm sure these will do very well for what I need it for. Once I have the car up and running ill give some feedback of how it performs during the season.
poorutron
Postby poorutron » Wed Jun 05, 2013 12:27 pm
What fitting was needed to be grinded down?
Rabid Machina
Postby Rabid Machina » Thu Jun 20, 2013 12:11 pm
poorutron wrote:What fitting was needed to be grinded down?
the brass fitting.
Lapdance
Postby Lapdance » Sun Jul 21, 2013 7:57 pm
What did you use as to center the heim joints on the car? Washers or spacers or are none needed?
poorutron
Postby poorutron » Thu Aug 08, 2013 10:04 am
Lapdance wrote:What did you use as to center the heim joints on the car? Washers or spacers or are none needed?
looks like your gonna have to do the same as 4 links and put washers as spacers to center the heim joints
fyi for anyone planning to do this on a SR5 rear (until you get a GTS rear) I'd suggest sanding down the axle side bolt mount thing as the heim joints dont fit (attempted to install this DIY bar yesterday and ran into that problem guessing there are size differences)
solo2go1
Postby solo2go1 » Tue Feb 04, 2014 8:48 pm
Tried doing this on a GTS rear end. The hole in the 3/4" heim joint won't fit on the axle side bolt which is .80" diameter.
3tcPower
Postby 3tcPower » Mon Mar 24, 2014 9:48 am
Bump for a good thread and apparently you can buy it as a kit(for the panhard bar)
http://speedwaymotors.com/Speedway-Panhard-Bar-Kit,59078.html
Is it a similar concept for the 4 link bars? And if so, does anyone have the measurements?
Straitup D
Postby Straitup D » Thu May 15, 2014 11:00 am
3tcPower wrote:Bump for a good thread and apparently you can buy it as a kit(for the panhard bar)
viewtopic.php?f=28&t=2597
AllenPDX
Postby AllenPDX » Tue Jun 17, 2014 11:37 am
solo2go1 wrote:Tried doing this on a GTS rear end. The hole in the 3/4" heim joint won't fit on the axle side bolt which is .80" diameter.
Anyone find a heim joint that would fit the GTS rear end mounting point?
marley4us
Postby marley4us » Tue Jun 17, 2014 2:47 pm
.05" smaller, have you tried drilling it out slightly, or using sandpaper on a bit and sanding .05" ? might work
SNOOZ
Postby SNOOZ » Wed Feb 04, 2015 12:05 pm
whats the length of the bar i should order if im using a sr5/gts rear end?
i saw marley is using a 27 but hes using the celica rear end ...
would the 26 in bar be the right size?
thanks
EXXX
Postby EXXX » Thu Feb 05, 2015 1:26 pm
For the Celica Supra I got a 29" bar from Speedwaymotors but the issues is the 3/4" hiem is too small for the diff side. The Diff Pan hard bar stud is 15/16" so you'll need to dremel the Hiem joint out abit. They do not sell a 15/16" hiem joint anywhere. I will post some pics of my set up next week.
