of the throttlebody (TB). The purpose of the AAV is to raise the idle speed on
a cold engine for better starting and faster warmup. It does this by admitting
extra air into the intake manifold when the engine is cold. The AAV contains a
water heated air valve controlled by the expansion and contraction of a wax
filled capsule. When the engine is cold, the valve is open. As the engine warms
up the water from the engine cooling system circulating thru the valve and
around the capsule heats the wax capsule. The capsule expands and gradually
closes the valve, reducing the amount of extra air entering the manifold.
When the AAV is operating correctly the cold idle will be around 2200 rpm.
This will drop to around 850-900 rpm when the engine is fully warmed up )if
the engine is running normally).
When the water side of the AAV becomes blocked, the cooling system water
can no longer circulate, and the engine will have a permanently raised idle.
If the warm idle remains above 1700 rpm the engine will start to cycle on the
fuel cut, and you will have the classic loping/cycling idle as if you were gently
revving the engine over and over again with the gas pedal.
To clean the AAV remove it from the TB and using a thin skewer, wire, knitting
needle, pipe cleaner (or whatever) work away at the water inlet and outlet
connections until the valve flows water freely from one to the other when you
hold it under a tap. Check the little rubber hose are clear also. The usual cause
of blockage in the AAV is rust particles or bits of silicone sealant from overdoing
cooling system repairs. Brake cleaner won't be much help to you. Once the AAV
is clean, put it back with a new o-ring and a new paper gasket available from
Toyota or included in any engine overhaul gasket set.
EDIT: Just to be clear, the arrow that says "Water Inlet" is pointing at the steel
tube, not at the little stub. Water goes up into the throttle body thru the steel
tube, and then comes back down thru the little stub and into the AAV.
