Rear output shaft bearing
Posted: Wed May 02, 2018 11:00 am
by sageren
Anyone know the proper dimensions of the rear output shaft for the T50? The stock I had on that I'm replacing is 63mm OD..the new one came with a 62mm OD. Just wanted to make sure before
Re: Rear output shaft bearing
Posted: Wed May 02, 2018 11:01 am
by sageren
for the bearing
Posted: Wed May 02, 2018 9:38 pm
by Autohaus_Z
sageren wrote:for the bearing
Do you have a picture? The T50/T51 rear output bearings are different. For a T51 (ae86) it should be shielded on the back side.
