MR2 7 ribs block for ae86
Posted: Wed Jun 27, 2018 1:34 am
by RLZ
Hi, does a bare MR2 7 rbis block fits with the accessories from an ae86 gts? thanks
Re: MR2 7 ribs block for ae86
Posted: Wed Jun 27, 2018 4:40 am
by davew7
The MR-2 block should swap right over into a GTS, assuming that you have the old RWD engine to change out the water pump, pulleys, manifolds, and flywheel, etc,etc. The only problem I've heard of is that some of the engine block bosses, i.e. engine mounts, where not tape out on the MR-2 blocks. In my case, everything was a direct transfer. DaveW
Posted: Wed Jun 27, 2018 8:17 am
by RLZ
davew7 wrote:The MR-2 block should swap right over into a GTS, assuming that you have the old RWD engine to change out the water pump, pulleys, manifolds, and flywheel, etc,etc. The only problem I've heard of is that some of the engine block bosses, i.e. engine mounts, where not tape out on the MR-2 blocks. In my case, everything was a direct transfer. DaveW
what year is your mr2 block? i do have everything from a 86 gts, thanks
Posted: Thu Jun 28, 2018 4:04 am
by davew7
It's a 1987 block. DaveW
Posted: Thu Jul 05, 2018 6:06 pm
by MisterJerk
Definitely will work. I have everything 16v bolted onto a bt20v (4th gen 4age)
