20V with Powersteering?
Has anybody done this? Does anyone know if the 16v powersteering pump just bolt on?
Re: 20V with Powersteering?
I believe the 16v power steering pump works just fine with any 20v. I just finished converting my 20v swapped car to manual steering and the pump appeared to be 16v (PO did the swap). You may need to steal the crank pulley off your 16v??
I'm sure someone else will chime in with the absolute truth, but I think you're should be good to go.
Lowtekk I appreciate the info!
