So I finally got around to getting the head work done, put it all back together and finally got it to run again. I noticed an oil leak and figured it was a few things which I quickly ruled out. Wasn't coming from the distributor, not the oil cooler lines nor the filter itself..
So I drained the oil and went to fill with new and it looks to be running down the block on the exhaust side. All I can figure is the headgasket I used is junk and the seals around the drain into the block have failed. Anyone else ever have this issue? Makes me really wish I had poured oil in it before reassembling everything else :/
