fuel return lines for carb
kingston
Postby kingston » Thu Dec 26, 2013 10:59 pm
just wondering what you do with the fuel return lines when you're going carbureted on a GTS. I have the return line as well as the hard lines from the canister sitting next to the firewall. Should I plug them up?
ga_goosh
Re: fuel return lines for carb
Postby ga_goosh » Mon Jan 06, 2014 1:02 pm
yes plug them or you might get pressure pushing out fuel through them. remove the charcoal canister and plug the return line that normally went to your fpr.
I <3 my AE86
4AG Manual
AE86 FSM
kingston
Postby kingston » Fri Jan 10, 2014 5:40 pm
should the lines be fully capped? Capping them won't build pressure in the tank?
ritz
Postby ritz » Wed Jan 15, 2014 9:03 am
you should have a gas cap that releases negative pressure. oem should be fine.
carbd7age
Postby carbd7age » Wed Jan 22, 2014 7:27 am
Capping mine built a lot of vacuum pressure in the tank. I never got around to making a rollover vent before I sold the car.
Knockoff Crew member #0001
canyon_carvers
Postby canyon_carvers » Thu Jan 23, 2014 3:44 pm
cap it
