oldeskewltoy wrote:oldeskewltoy wrote: there is no engine fan, mechanical driven or electric, has made me a bit uncomfortable. David (previous owner) said it wasn't a problem, after all this is a race car, it is used on track........
As this car's purpose has changed somewhat, besides the bits I've already mentioned, I'll be adding a thermo-switched electric fan to keep temps under control in less then perfect racing conditions.
More to come.......
key part to getting the fan in, and operational is the proper parts. Below is a coolant inlet for an AE82. This will bolt in as the stock one does, and is even pointing in the correct place. The original Toyota switch is grounded, and when hot it breaks the ground(opens) and the fan comes on. This works as a safety as well, if the switch breaks, the fan stays on.
For Racecar I'm using a Honda switch, that will be open, and close @ temp (reverse of Toyota switch). This makes wiring the fan a bit simpler since the Honda switch is more conventional in operation.
BUT... the sensor doesn't quite fit. The hole for the probe is too narrow, and the threads aren't deep enough. So a few mods....
and the Honda switch becomes right at home....
with just enough of the sensor in the coolant to operate, yet not so far in that it seriously disrupts flow
more to come.....
I'm getting ready to wire up my e-fan and would love a more simplified system. You should let me know how this works out, because I was thinking of doing the Toyota "normally closed" method initially.
