MR2 7 ribs block for ae86
RLZ
Postby RLZ » Wed Jun 27, 2018 1:34 am
Hi, does a bare MR2 7 rbis block fits with the accessories from an ae86 gts? thanks
davew7
Re: MR2 7 ribs block for ae86
Postby davew7 » Wed Jun 27, 2018 4:40 am
The MR-2 block should swap right over into a GTS, assuming that you have the old RWD engine to change out the water pump, pulleys, manifolds, and flywheel, etc,etc. The only problem I've heard of is that some of the engine block bosses, i.e. engine mounts, where not tape out on the MR-2 blocks. In my case, everything was a direct transfer. DaveW
RLZ
Postby RLZ » Wed Jun 27, 2018 8:17 am
davew7 wrote:The MR-2 block should swap right over into a GTS, assuming that you have the old RWD engine to change out the water pump, pulleys, manifolds, and flywheel, etc,etc. The only problem I've heard of is that some of the engine block bosses, i.e. engine mounts, where not tape out on the MR-2 blocks. In my case, everything was a direct transfer. DaveW
what year is your mr2 block? i do have everything from a 86 gts, thanks
davew7
Postby davew7 » Thu Jun 28, 2018 4:04 am
It's a 1987 block. DaveW
MisterJerk
Postby MisterJerk » Thu Jul 05, 2018 6:06 pm
Definitely will work. I have everything 16v bolted onto a bt20v (4th gen 4age)
