AE86 Lower rubber radiator mounts
toyzilla
Postby toyzilla » Sat Oct 13, 2018 9:04 pm
Hey guys, I'm having a very hard time finding some AE86 lower rubber radiator mounts. I looked online for them, but no luck. Is there any cross models like Honda, Nissan or any other Toyota model that would fit? Thanks Guys...
Nick94tt
Re: AE86 Lower rubber radiator mounts
Postby Nick94tt » Sun Oct 14, 2018 9:22 pm
For what it's worth, I've used heater hose as a spring insulator without issue.
Odds are any spare rubber fuel line, power steering return hose, or small heater hose can be used to rig up a decent bushing.
Hope it helps,
Nick. ^_^
toyzilla
Postby toyzilla » Sun Oct 14, 2018 10:14 pm
Thanks Nick94tt, so basically we don't want the bottom of the tank hitting the radiator support. By using a three inch long hose with a hole that the radiator dowel pin will fit, should do the trick... Not very pretty, but I think it might work.... LOL... :lol: Hey, Thanks Nick94tt...
Postby jondee86 » Sun Oct 14, 2018 10:25 pm
Nick94tt
Postby Nick94tt » Mon Oct 15, 2018 10:26 am
jondee86 wrote:http://www.hachiroku.net/forums/forum/main-category/tech-and-performance/34788-diy-radiator-isolater-bushings
I had a feeling someone would have the non-hack answer, lol. Been a while since I installed my aluminum radiator (5 years or so...)
:lol:
Last time I did similar was to save a friend some money after they had a small mishap in a cavalier. Repairs were going to cost more than the car was worth - retail. :lol: :lol: :lol:
toyzilla
Postby toyzilla » Tue Oct 16, 2018 1:13 am
Hey thanks a lot guys.. I really appreciate your help..
Rogue-AE95
Postby Rogue-AE95 » Tue Oct 16, 2018 3:50 am
I know it's not quite the same setup, but when I fit a Honda Civic "half size" aluminum radiator into my AE95 I had temporarily used one of these (or another size, I forget) on the Civic rad mount that I had to add.
https://www.homedepot.com/p/Everbilt-3- ... /203661016
Of course I had ordered the correct Honda part, but for temporary purposes this leg tip thing worked fine with some slight modifications.
toyzilla
Postby toyzilla » Tue Oct 16, 2018 9:17 pm
That so funny, because I have a Honda Civic half radiator as well and plan A was to install it in my AE86. Modifying a lower radiator support bracket would be a bit stressful, so decided to go to plan B. An aftermarket aluminum stock replacement. But after buying this radiator, that's where my journey began... lol... :lol: But, thanks a lot guys.
