i connected the +12v to the pin 1 and 9 of left plug, and the ground to pin 2 of left plug and pin 8 of right plug, connected tach signal (-) to pin 11 of left plug, and water temperature sender (-) to pin 7 of left plug. this is my basis for the wiring.
i also uploaded the video to share what i have done.
http://youtu.be/OWGWSznHaRM
as you see, the tester reads Hz and it increases if i rev the engine, but the rpm doesn't move. also, notice the temperature is not changing, but i checked the resistance and it varies depending on the temp.
it's hard to determine it is hardware fault, i have no spare to check, but when i use the analog cluster, it works. looks like the IC has defect? or I am missing something +12v?
4age 20v / ke70
ae86 digital cluster tachometer/water temp not working
Re: ae86 digital cluster tachometer/water temp not working
check out mr. rongfk's posts. He sometimes sells the adaptor harness, that he makes.
Help support our forum and our scene.
http://club4ag.com/forums/viewtopic.php?f=15&t=5119
thank you. I will contact him now. Also, anyone already tried to hook up a 3-wire electronic speed sensor to this digital cluster? I already have the modified speed sensor, but I still have to think how to connect it to the cluster. thanks
Ever figured out what was wrong with those gauges?
choyr wrote:thank you. I will contact him now. Also, anyone already tried to hook up a 3-wire electronic speed sensor to this digital cluster? I already have the modified speed sensor, but I still have to think how to connect it to the cluster. thanks
Any news on that?
Yes....did anyone try this? Also ... anyone get the speedo to read over 180kmh / mph? I note that the speedo has room for 200+ when taken apart.
Dear all, just to bump the topic, cluster still not working. I had the time to disassemble the PCB and found the labels on the back connector. Anyone knows these? What I want to do is not to install a digital fuel sender, because it's currently installed in a race car with a fuel cell. What I need is only the rpm and temp. Speed is already working, I just want to bypass the fuel level.
Thanks if someone can help.
Hey bro I just wired up mine and the tach isn't working aswell. You ever get to the bottom of it?
always looking to buy original ae86 master power window switches or parts, good or broken or not working.
look for my parts for sale...
rongfk1963@yahoo.com
