Need assistance! ST 20v map conversion
newbie20v
Postby newbie20v » Fri Nov 28, 2014 3:41 am
I have a toyota marino with a silvertop swap and i do not have afm to have the car up and running so was thinkin of a map conversion. Did alot of reading but was very confused so decided to ask directly on a forum. If this issue has been addressed then please do direct me. I do have map and iat sensors and blacktop ecu (iam running auto atm). I read sumwea that blacktop oxygen sensor is needed ... didnt kno there was a difference between them so please help ...
What i need help with is :
-wea should i connect vaccum line for map
-how to wire map and iat to existing afm lug
-ecu pinouts ... dnt kno which ones to swap
Re: Need assistance! ST 20v map conversion
Postby jondee86 » Fri Dec 05, 2014 5:25 pm
I haven't done this conversion, but there is some pretty legit looking info
in this thread... http://forums.club4ag.com/zerothread?id=35079
Pinouts can be found here... http://club4ag.com/technical_main.htm
For the MAP sensor, you can tap/tee into any line that connects the the
common vacuum rail. The line marked in orange in this pic would be most
suitable...
