check engine 4age blue top (Code 6)
hjmoncada
Postby hjmoncada » Wed Jan 06, 2016 2:59 pm
i friends.
I have a problem with the check engine
checking engine is always on
but low rpm 500 is off
but if I go up to over 4500 rpm shuting off automatically
but when he returns to between 500 and 4500 rpm check the engine on again
that could be the problem?
Re: check engine 4age blue top
Postby jondee86 » Thu Jan 07, 2016 12:42 pm
Hi and welcome to club4AG :)
Have you tried to see if there are any fault codes stored in the ECU ?
To do that you have to short the two pins of the diagnostic plug with
a piece of wire, turn the ignition on, and read how many times the
CEL flashes.
hachipirate
Postby hachipirate » Thu Jan 07, 2016 1:33 pm
Welcome to the club.
Like jondee said, have you gone through basic diagnostic procedure? Is it stock? What modifications?
hjmoncada
Postby hjmoncada » Sat Jan 09, 2016 5:03 pm
I made the bridge with a cable.
engine checking flashes 6 times and turns off.
delete the codes stored in the ECU and bridge again
flashes 6 times and this approximately three seconds off
but always in less than 500 RPM engine checking off
and when I step 4500 RPM turns off
I mean between 500 -4500 is always on the check engine
I will make a video link and will share them
sorry my english still in learning
Postby jondee86 » Sat Jan 09, 2016 5:55 pm
For an AE86 error code 6 is:
Code 6 RPM signal.
No Ne, G signal (engine revolution sensor) signal to ECU within
several seconds after engine is cranked. No Ne, G signal (engine revolution sensor)
signal to ECU within several seconds after engine reaches 1,000rpm.
Places to look:
Distributor circuit.
Distributor.
Igniter.
Starter signal circuit.
ECU.
I'd start by checking all the wiring around your distributor and igniter. Look
for broken or frayed wires, damaged plugs, shorts, burned wires. In particular
look at the wires just where they connect to the distributor which is where they
move around the most.
PS: You only need to post the question one time and then wait for an answer ;)
hjmoncada
Re: check engine 4age blue top (Code 6)
Postby hjmoncada » Sun Sep 24, 2017 5:25 pm
some people here have a full manual repair for this car in pdf not have this part
Postby jondee86 » Sun Sep 24, 2017 6:40 pm
You can download it here... http://files.aeu86.org/manuals/4A-GEManual.pdf (92Mb)
Also the AE86 body manual... http://files.aeu86.org/manuals/AE86Manual.pdf (100Mb)
hjmoncada
Postby hjmoncada » Sat Oct 13, 2018 9:35 am
in this manuals page to check code 6 dosent exsit
Postby jondee86 » Sat Oct 13, 2018 3:56 pm
It is Page 85 in the download manusl... same information as this...
hjmoncada
Postby hjmoncada » Sat Dec 22, 2018 10:31 am
but the manuals dont have page about how repair ditributor
Postby jondee86 » Sun Dec 23, 2018 4:16 pm
From the club4AG FAQ....
4AGE 16V - Distributor Rebuild - DIY by Matrix Garage
Users browsing this forum: Google Adsense [Bot] and 4 guests
