FS: Hella Misc parts
Autohaus_Z
Postby Autohaus_Z » Sun Oct 09, 2016 2:47 pm
Megan Engine/Trans mounts (installed only, essentially new) $100
C's short shifter w/ T3 bushings $280
T3 NCRA. One hole each has a fresh helicoil repair. 2 bolts are missing. $40 Shipped
Factory rod bearing (One rod only, I had an extra, Size 3) $5
T3 Heim joints x4 $60
T50 tailshaft/extension housing bushing (none left in the USA) $100
Parts listed below are NIB
33403 19175 SR5 Speedo Gears x3 (includes Oring and clip) $20ea
Factory Toyota T50 Syncros (5 Piece) $150
04331 14030 T50 Gasket kit $30
90507 14003 Clutch/Brake Pedal Springs (DISCONTINUED) $offer
33404 16010 T50 speedo gear housing $25
44730 10010 Brake Booster Check Valve $20
89422 12010 Water Temp Sensor $40
89424 28010 Oil Pressure Sensor $40
90365 20004 T50 Front Counter Shaft Bearing (DISCONTINUED) $120
90365 20001 T50 Rear Counter Shaft Bearing (DISCONTINUED) $120
I also carry a lot of new and used T50 transmission parts! Feel free to inquire!
Located San Jose, CA.
Email or call/txt
xearthwindandfirex@yahoo.com
four zero eight 781-one 191
Thanks!
RnD/Product Testing. Battle Garage Racing Service.
Autohaus_Z
Re: Ae86 Parts
Postby Autohaus_Z » Fri Oct 14, 2016 8:18 pm
Bump. Camber plates sold.
Autohaus_Z
Re: Ae86 misc, Springs, Interior, Gaskets
Postby Autohaus_Z » Mon Dec 12, 2016 4:16 pm
Bump. Many new parts. Prices adjusted.
kim julio
Postby kim julio » Tue Dec 13, 2016 9:31 pm
hello
T50 paper gasket set $10
NST underdrive FWD/20v water pump $20
send invoice
kimjulio@gmail.com
julio yao qbox1025
2292 N.W. 82nd Ave
Miami FL 33198
United States
(305) XXX-XX50
thank you
Autohaus_Z
Postby Autohaus_Z » Thu Feb 16, 2017 6:21 pm
Bump. Got another T50 gasket kit for sale!
Autohaus_Z
Re: Rebuilt T50 + parts, Gaskets, pulleys
Postby Autohaus_Z » Sun Mar 26, 2017 2:14 am
Bump. More cool parts!
sekang0
Postby sekang0 » Sun Apr 02, 2017 12:59 am
Great seller!
'85 GT-S project since 2010
Autohaus_Z
Re: Misc parts, Syncros, RCAs, ect
Postby Autohaus_Z » Sat May 27, 2017 11:30 am
Bump. More items added. Selling new T50 Syncros now!
Autohaus_Z
Re: Misc parts, T50, Brakes, ect
Postby Autohaus_Z » Sun Jul 30, 2017 12:39 am
Bump. Got my pictures back, added more parts!
S_p_R_i_T_e
Postby S_p_R_i_T_e » Sun Jul 30, 2017 3:42 pm
Would nst pulleys work for 20v rwd (in 86)?
Autohaus_Z
Postby Autohaus_Z » Sun Jul 30, 2017 7:42 pm
S_p_R_i_T_e wrote:Would nst pulleys work for 20v rwd (in 86)?
The water pump pulley will work. The p/s pulley lines up if its a silver top (you need shorter or longer belt, I forget)
Postby totta crolla » Tue Aug 01, 2017 12:50 am
Would you send the P/S inner tie rods to the U.K ?
Autohaus_Z
Re: T50 Rebuild kit, Brakes, Pulleys, ect
Postby Autohaus_Z » Sun Aug 06, 2017 1:48 pm
Bump. More parts, plus a full T50 Rebuild kit Ive been hoarding.
CloudStrife
Postby CloudStrife » Tue Aug 08, 2017 12:10 pm
May I ask why the brake brackets were trimmed? Thanks man.
Autohaus_Z
Postby Autohaus_Z » Mon Aug 14, 2017 1:46 am
CloudStrife wrote:May I ask why the brake brackets were trimmed? Thanks man.
More air flow for the brakes. My 86 sees plenty of track time. Lots of oems either run a brake splash shield without a "lip," or none at all. Thats why I modified mine.
Autohaus_Z
Re: 4.778, Rear shocks, T50, Gauges ect...
Postby Autohaus_Z » Tue Feb 06, 2018 2:07 am
Bump. Cool new parts added!
Autohaus_Z
Re: FS: Hella Misc parts
Postby Autohaus_Z » Sat Apr 14, 2018 8:18 pm
BUMP HELLA NEW PARTS ADDED!
