4age 230hp Fat Performance/Formula Atlantic Style engines and parts for sale
Rwddriftsvx
Postby Rwddriftsvx » Tue May 23, 2017 9:51 am
-Selling 1 Complete Fat Performance Toyota 4age engine 230hp Small port, Comes with electromotive xdi ignition system with crank trigger pickup. This is a Formula Atlantic engine more or less but with a wet sump system. Fat performance was one of the California based engine builders to build and service Toyota Atlantic spec. Engines. Has a weber 44idf down draft with custom plenum from Fat. Can be run with twin side drafts as well. But must buy plenum and carbs. will need flywheel if not being used in a buggy.Asking $3000 for complete pulled-running engine.
-Extra Parts include
-stock used 4age crank
-one small port 4age head (stock no cams)
-one stock largeport head (stock with cams)
-one bare block (needs hone)
-2 sets of valve covers with 10an breather fittings
-10 quart Dooley desert oil pan with fittings for dry sump
-Power steering brackets
-Cam covers and seals
-Timing covers and seals
-2 sets of JE Pistons- 82.5mm and 82.6mm sets
-Lightened flywheel for vw/mendeola trans
-Tri-y buggy header
-4-1 buggy header
-N.O.S 7afe Crank
-Other random parts included
Due to File Size, please contact me for pictures
Located In Green Bay Wisconsin.
Local Pickup Preffered or buyer must arrange shipping.
Jafet
Re: 4age 230hp Fat Performance/Formula Atlamtic engines and parts for sale
Postby Jafet » Wed May 24, 2017 5:06 pm
Is the $4000 Formula Atlantic a 20v or 16?
kakico
Postby kakico » Thu May 25, 2017 4:28 am
pictures
interested
Rwddriftsvx
Re: 4age 230hp Fat Performance/Formula Atlantic Style engines and parts for sale
Postby Rwddriftsvx » Thu May 25, 2017 7:00 am
Please pm me with email for pictures. Engines are usually 16 valve smallports as most FA engines are. These are a wet sump version of F/A seeing in the offroad world the weight location and larger capacity oil pans are needed. One engine does have ports to run a dry sump setup on the pan however. Again, easier to pm/ email pics. Thanks!
kakico
Postby kakico » Sun May 28, 2017 5:42 am
I did sent a pm
Rwddriftsvx
Postby Rwddriftsvx » Mon May 29, 2017 2:38 pm
Responded^
Rwddriftsvx
Postby Rwddriftsvx » Tue May 30, 2017 10:51 am
We do not want to separate anything, these are engines we will use as well as parts. all parts get sold together, all engines get sold together etc
LePimpOfPimps
Postby LePimpOfPimps » Sun Jul 02, 2017 3:42 pm
what's the Cam grind codes on the intake and exhaust,.
1976' Corolla/Levin TE37 3TC
Rwddriftsvx
Postby Rwddriftsvx » Mon Aug 07, 2017 11:11 am
I will have to look later at the cam grinds. They are web custom spec'd for offroad use by FAT, powerband is from 6k+
slow_poke
Postby slow_poke » Wed Aug 09, 2017 11:16 pm
Sorry to ask again. Willing to split the spare parts? Sorta looking for a 7-rib 'SC block
Rwddriftsvx
Postby Rwddriftsvx » Wed Aug 16, 2017 6:00 am
Let me see what we have available and if it would be reasonable to sell separate. Send me a personal message and we can talk
slow_poke
Postby slow_poke » Fri Aug 18, 2017 5:10 pm
sent you a PM. did you get it?
Rwddriftsvx
Postby Rwddriftsvx » Tue Jan 16, 2018 6:10 am
Sorry, been gone for a while here. I did and I will have to look into the blocks for you
Gabriel82
Postby Gabriel82 » Wed Apr 18, 2018 11:28 pm
Message sent
Steering racks-Steering pumps-Steering gear boxes
http://www.steerandsave.com
steerandsave@gmail.com
Instagram: steerandsave
SOCAL/NOCAL area
