dry sump pan suit 3sge any generation
celicaRA45
Postby celicaRA45 » Sat Apr 21, 2018 8:00 pm
i have 1 dry sump pan to fit any generation 3sge price is in aud dollars of 650 plus postage to any where in the world
rickjames319
Re: dry sump pan suit 3sge any generation
Postby rickjames319 » Thu Jun 28, 2018 6:39 pm
So that is a blank casting? It would still require machining of mounting holes and oil return ports? Or is it more complete than it appears to be? Also do you have anything else to go with that like a pump and crank pulley with provisions for a oil pump belt?
celicaRA45
Postby celicaRA45 » Fri Jul 06, 2018 11:55 pm
pan will be drilled and set up to suit any generation 3sge and will fit beams as well ,i also have a kit as well
rickjames319
Postby rickjames319 » Tue Jul 10, 2018 4:55 pm
How much are you asking for the whole kit to go with it?
celicaRA45
Postby celicaRA45 » Wed Jul 11, 2018 4:17 am
i sent you a pm
Return to “General Accessories and Parts”
