ae82 struts
oldae82
ae82 struts
Postby oldae82 » Fri Sep 14, 2018 6:12 pm
OK, in the search for the noise/click/ in the steering I decided to install new struts and bearing caps. After searching managed to find the four bolt bearing caps, and ordered them. Ordered a set of struts that were supposed to be for fx16 and fx16gts. Struts came, but the cup in which the bottom of the coil spring sits was about 1/2" too small for my coil spring. Decided to put the new bearing caps on the old struts, but found the inside diameter of the sleeve for the strut piston rod was 22mm and the strut piston rod of my strut was 20mm. Had an old strut assembly with the piston rod of 22mm, but they're totally worn out. By my reckoning there are three possible combinations: 22mm strut piston rod w/6 1/2" diameter coil spring; 20mm strut piston rod w/6 1/2" diameter coil spring; and 20mm strut rod piston w/6" diameter coil spring. There may even be more, but I've got these three in my shop, except I don't have any strut with an actual 6" diameter coil spring. How can I sort this out and get the proper combination? The old bearing caps sound like my knees, so I don't want to reuse them.
