PnP digital ae86 cluster adapter
rongfk
Postby rongfk » Wed May 29, 2013 8:30 am
if anyone is interested, i offer a plug and play adapter to install the rare jdm ae86 digital cluster in a LHD ae86 gts or sr5. there are other components needed the make the cluster function properly any questions just inquire. i developed this adapter back in 2009 for my own ae86 and decided to offer this to everyone else, a lot of time and research has gone into the development of this adapter. With my adapter harness there is no need to cut anything on your cars wiring which makes this easy to go back to analogue if you choose. asking $300 + shipping & PayPal fees (4%) for the adapter with the digital oil & water sensors included. my price is firm and fare considering a shop would charge you upwards of $500 just to hack you car up to install one. this price is with you supplying me with an analog ae86 cluster (stock) otherwise the price will be $350 + shipping & PayPal fees.
Update 1/11/15
I am out of factory ae86 clusters so if you are interested in this, get at me and I can tell you what to send me off of your donor cluster or you can just add $50 to the price for me to source out one for you. In which case will be $350 + shipping and paypal fee's
update 5/8/17
*you might be able to use this as an alternative for the fuel sender. (but i have not tried it)
http://www.ironcanyonmotorsports.com/icm-fuel-sender/
(you would have to select the "CUSTOM" one and set the value to 13-310 Ohm values)
another update 4/10/18
this one look more promising for a fuel sender alternative their are you tube videos on how to set it up also
https://www.spiyda.com/fuel-gauge-wizard-mk3.html
thanks, Ronnie.
VIDEO
http://www.youtube.com/watch?v=MxpL7tzc7MU
here is a picture reference of the digital clusters and sensors iv'e sold in the past (the whole set up with instructions was selling for $600 at the time). iv'e owned and sold 5 of these set ups, and a lot of time and research has gone into these.
always looking to buy original ae86 master power window switches or parts, good or broken or not working.
look for my parts for sale...
rongfk1963@yahoo.com
shannon
Re: PnP digital ae86 cluster adapter
Postby shannon » Wed May 29, 2013 11:53 am
wow! very very nice! for those of you who aren't familiar with how to install jdm analog or digital clusters this will save you so much time and frustration.
i did a wiring harness similar to this for my jdm analog cluster so i can go back to usdm if i want. bump for you.
Pogipoints619
Postby Pogipoints619 » Wed May 29, 2013 1:41 pm
Bump for Rongfk, bought one of his harness awhile back.. good stuff reliable and doesnt hack up your og harness.
In addition to the fuel sending unit, you will also need to change your oil pressure sending unit to an sw20/3sgte to avoid an oil light fluctation.
Free Wing Chun/kickboxing training sessions in the SoCal Murrieta/San Diego
Saturdays
marley4us
Postby marley4us » Wed May 29, 2013 2:23 pm
I was wondering if you would have any advice... I am running a NX1600 digital dash out of a nissan. How did you swap the fuel sending unit to a digital for your JDM digi cluster? any info would be greatly appreciated!
1994 4runner (The truck)
rongfk
Postby rongfk » Wed May 29, 2013 2:31 pm
^^thanks guys
its plug n play, just swap out the analog sender for the digital one(blue top like the ones in my second pic). same set up, just gives out a different signal. not sure if it will work with your nissan cluster, but if a digital signal is all you need that this is the way to go.
builtnotbought
Postby builtnotbought » Wed May 29, 2013 3:52 pm
I bought one from rongfk, WOrks good with my setup. thumbs up
full_lock 86
Postby full_lock 86 » Wed May 29, 2013 9:07 pm
Ygpm!
rongfk
Postby rongfk » Fri May 31, 2013 1:35 pm
thanks, one gone two available still.
rongfk
Postby rongfk » Wed Jun 05, 2013 6:36 pm
You can search my screen name on YouTube to see my cluster working with one of my adapters. Bump 2 still available.
marley4us
Postby marley4us » Thu Jun 06, 2013 1:30 am
how much for a digital fuel sending unit?
rongfk
Postby rongfk » Thu Jun 06, 2013 6:42 am
only have the adapters, oil, & water sensors available right now.
rongfk
Postby rongfk » Fri Jun 14, 2013 8:11 am
bump, have another available. can do the harness, and both digital oil and water sensors for $250 shipped
Tsuchi921
Postby Tsuchi921 » Fri Jul 26, 2013 12:00 pm
Hey RonGFF. So if I were to get a digital cluster this would be all I need inorder to get it to work with my USDM Zenki? Thanks in advance.
rongfk
Postby rongfk » Sat Jul 27, 2013 12:25 pm
To make the JDM digital cluster work in a usdm car, you need my harness adapter, digital fuel sender, digital oil sensor, and a digital water sensor.
mrkona
Postby mrkona » Wed Jul 31, 2013 9:03 am
This harness works perfectly !
rongfk
Postby rongfk » Thu Oct 24, 2013 7:05 am
have the parts to make another if anyone needs it?
The Robot Cow
Postby The Robot Cow » Thu Oct 24, 2013 9:22 pm
Will this work for me if I already have a digital dash but I want to go back to an analog cluster? Or a JDM analog?
1985 Corolla Gts Coupe
ryceboy_124
Postby ryceboy_124 » Thu Oct 24, 2013 10:56 pm
Bought this adapter from you not too long ago but haven't started my coupe project just yet...How much for the digital oil & water sensors?
rongfk
Postby rongfk » Fri Oct 25, 2013 8:49 am
The Robot Cow wrote:Will this work for me if I already have a digital dash but I want to go back to an analog cluster? Or a JDM analog?
it probably wont, if your car has been converted by someone else it may be hacked up or rewired, or if its a jdm car or clip it wont. take your cluster out and take a picture for me, I still may be able to help if it is a jdm harness. I can make a conversion harness for that too, it will cost more that $200 though. ill have to research and reconfigure a diagram for it. figure out if you are going to go jdm or usdm analough because they are completely different.
ryceboy_124 wrote:Bought this adapter from you not too long ago but haven't started my coupe project just yet...How much for the digital oil & water sensors?
sent a PM
The Robot Cow
Postby The Robot Cow » Fri Oct 25, 2013 10:43 am
Hmm... I know that Racetoys did the wiring of my digital cluster when it used to belong to a former owner. It's probably a rewiring then.
rongfk
Postby rongfk » Mon Oct 28, 2013 10:04 am
The Robot Cow wrote:Hmm... I know that Racetoys did the wiring of my digital cluster when it used to belong to a former owner. It's probably a rewiring then.
no worries, I can probably help you on rewiring it to factory also.
bump!
rongfk
Postby rongfk » Wed Dec 18, 2013 8:08 am
I am out of stock analogue clusters so if you need an adapter to be made I need you to bring one or send one to me. either a sr5 or gts cluster will work.
socal_levin_ae86
Postby socal_levin_ae86 » Wed Dec 18, 2013 3:30 pm
HEY ILL TAKE ONE TEXT ME (714)614-8248
SNEAKERHEAD
Postby SNEAKERHEAD » Tue Dec 24, 2013 5:38 pm
Sick! Now to find a cluster.
xbenny1x
Postby xbenny1x » Thu Jan 09, 2014 6:39 pm
I need one pm me plz I just need wire diagram , and for water n oil , thanks
rongfk
Postby rongfk » Thu Jan 30, 2014 7:43 am
if you need a conversion harness just send me your stock clusters so that I can make a harness out of it.
xbenny1x email me
Boyeas Factory
Postby Boyeas Factory » Mon Feb 17, 2014 8:38 pm
Very interested in getting one of these harnesses and the oil and temp sensor's if you still have any available. I also sent you email.
Formally known on the old Club 4AG as ( Camber King )
xhachiroku
Postby xhachiroku » Thu May 08, 2014 11:25 am
Hey I emailed you about the conversion harness yesterday.
rongfk
Postby rongfk » Mon May 12, 2014 6:32 am
All I need is for you guys to send me an ae86 cluster that I can use the parts from to make one.
SNEAKERHEAD
Postby SNEAKERHEAD » Tue May 13, 2014 7:52 pm
THANKS GOT MINES AND WORKING GREAT!! :D
