convert auto fx to manual
oldae82
Postby oldae82 » Sat Oct 18, 2014 8:09 pm
I've found an '88 fx (not -16) w/ auto. I'm looking at it as a donor body for my '87 fx16 5-speed. How big a chore is the conversion?
saiGone
Re: convert auto fx to manual
Postby saiGone » Mon Oct 20, 2014 8:57 am
FX is front wheel drive...
I'm guessing:
Tranny/ mounts
Clutch/ flywheel/ bolts
shifter/ linkage
axles (Possibly)
Clutch master cylinder/ slave cylinder/ hard lines/ soft line. (If the FX is cable clutch disregard)
Clutch pedal assembly
oldae82
Postby oldae82 » Mon Oct 20, 2014 2:41 pm
Thanks for responding. I guess what I most need to know is if the bodies of the auto and manual are the same i.e all the mounting points in the cabin and engine bay are there for either transmission option, or if they're different creatures.
Rogue-AE95
Postby Rogue-AE95 » Mon Oct 20, 2014 3:11 pm
I'd also add the brake pedal, which is usually different from auto to manual cars (don't know about the FX, but most likely). Autos typically have a wider brake pedal than a manual.
'88 Corolla All-Trac
sirdeuce
Postby sirdeuce » Mon Oct 20, 2014 3:47 pm
How close to Fresno CA are you? I have an '87 you can pick at.
One shot, one kill.
saiGone
Postby saiGone » Tue Oct 21, 2014 10:10 am
oldae82 wrote:Thanks for responding. I guess what I most need to know is if the bodies of the auto and manual are the same i.e all the mounting points in the cabin and engine bay are there for either transmission option, or if they're different creatures.
Not too sure about FX, but AE86 uses a different cross member to bolt to the chasis
oldae82
Postby oldae82 » Sun Nov 02, 2014 6:49 am
Thanks for the thoughts. I've pretty much decided its more work than it's worth. I'll have to obsess over something else.
jrae82
Postby jrae82 » Sun Nov 02, 2014 7:15 pm
Auto and manual chassis are the same. All you need is
Tranny (can use a ae92 one)
Rear and side driver tranny mount with brackets. Front one is the same (ae82 only)
Shifter links (can use ae92 shifter links)
Clutch slave cylinder (ae82 only)
Master brake cylinder (ae82 only)
Hard lines from brake master to slave cylinder (ae82 only. But I heard u can modify ae92 hard lines)
Axles. U can use ae92 axles 1 piece design. Less of a hassle
U can use auto ae82 brake pedal
Shifter (ae82 or ae92 one)
Rewire reverse and bridge big flat wires that go into auto trans so it can start
It took me like 2-3 hrs to put in and have running. And I was taking my time.
Its not hard
oldae82
Postby oldae82 » Mon Nov 03, 2014 5:28 pm
That's pretty slick. Would still have to convert the rest of the fx to fx16: wiring, brakes, suspension, but you've made a major part of it seem simple. Thanks.
