need help identifying this gze transmission.
Posted: Sun May 24, 2015 10:34 am
by turboae92
Need to know if this transmission is an Lsd version and if anyone has put together axles from other yotas to work with this transmission on an ae92.
Re: need help identifying this gze transmission.
Posted: Sun May 24, 2015 8:48 pm
by sirdeuce
Looks like an E-58, non LSD. If the bell bolts to a 4ag, it's most likely from an AE101.
Posted: Sun May 24, 2015 9:46 pm
by ae90tuner
On the E series transmission the factory viscous lsd has the bar in the diff and the open diff has a small circular openning. The aftermarket diffs for the E series also has the small circular hole opening in the diff.
The only lsd axle that will work aside from the factory one is the mr2's lsd axle stub.
Posted: Mon May 25, 2015 8:14 pm
by turboae92
Thank you both, after further research and seller confirming that it's lsd tranmission.Now I need to find some lsd axles, can anyone help me get them.
Posted: Tue May 26, 2015 7:06 am
by ae90tuner
You should ask around in mr2oc. Im positive the sw20 lsd axle stub works. You will need a shorter driverside axle. Chico race works sells a aw11 gze length axle.
http://www.monkeywrenchracing.com/produ ... ts_id=1252
Posted: Thu May 28, 2015 7:03 am
by turboae92
Thanks for your help ae90tuner, will contact this vendors to who can help.
