uz manual trans swap!
hachirokusoarer07
[url]http://pre15.deviantart.net/c411/th/pre/i/2014/263/9/c/wangan_midnight_vs_initial_d_by_alalagriffin-d7ztnbb.jpg/url]
Re: uz manual trans swap!
Do you mean from the manual sc 300? That would be a w58 transmission. And yes you can put just about any manual transmission behind a 1uzfe. But you will need a custom adapter plate and custom flywheel for any transmission you choose to go with none where bolt on unfortunately.
Sent from my SM-N910T3 using Tapatalk
hachirokusoarer07
ok so any know any way i can actually get a custom flywheel and adapter plate? or something similar i can just drill new holes into?
- ToeKnee805
if its the same as doing a manual 1UZ ae86 swap. I believe you can use a W58 transmission. Manual Swap Bellhousing. Hydraulic Throwout Bearing, 5VZFE Flywheel, and MR2 3sGTE Clutch. And a one off driveshaft.
Man be a stripper for a weekend, get the money for a Collins adapter kit, that way you can run w58, z32, z33, ka24, the whole shebang off one plate.
