Dyno/Build Pages...
Dyno/Build Pages...
Postby oldeskewltoy » Tue Jan 22, 2013 9:36 am
This is an entirely new thread in Club4AG. I will need your cooperation. PLEASE do NOT litter this thread with ANY comments... be they good, or bad... approval, or disapproval.
If you NEED to comment... PLEASE go here - viewtopic.php?f=13&t=1336
This thread is for build information backed up with dyno results ONLY.
4AGE, N/A, on stock AFM based engine management: #s measured @ the wheels
Engine model and generation:
4AGE - TVIS head/Silvertop block
Top End Modifications:
large port head - bowls/seats ported(no other porting), pinned and port matched intake/TVIS/head, Web 294 cams, AEM camgears(intake advanced 3 degrees), RC 225cc injectors
Bottom end modifications:
20V silvertop stock except 16V OEM high compression pistons(10.3 to 1)
Management:
factory ECU
Fuel used
89+
Intake:
K&N FIPK
Exhaust:
KBD header, Fujitsubo LegalisR large muffler twintip
Driveline:
Silvertop flywheel
OEM AE92 disc and pressure plate
Other Info
The above dyno run was done with a tired 20 year old fuel pump!
Re: Dyno/Build Pages...
Postby oldeskewltoy » Tue Jan 22, 2013 9:38 am
4AGE, N/A, MAP based aftermarket management: #s measured @ the wheels
Short and sweet
AE92 smallport head - ported
Web 577 camshafts, T3 timing pulleys set to 111 degrees
AE92 high comp block w squiters plugged, decked, stock head gasket
Euro TVIS pistons(10 to 1)
final measure compression ratio of 10.75 to 1
AE86 "small" crank w 40mm rod journals, lightened, shotpeened, and balanced "3 rib bluetop type"
AE86 small connecting rods - lightened, shotpeened and balanced
wrist pins are aftermarket steel 64 grams vs 89 grams for stock
blacktop flywheel w AE92 clutch
crank pulley is OEM 2 row, machined and rebalanced as a single row
KBD 4/2/1 header
Brave 60mm exhaust
FJO racing management
sequential injection
wasted spark ignition
running on 92 octane fuel
http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/Surreptitious1stdyno.jpg
141whp @ 7468, 108#s wheel torque @ 6127rpm.
Engine numbers(back calculated by their dyno) 164hp @7468, 128ft/# 6127rpm[/SIZE].
ariel_86
Postby ariel_86 » Sun Apr 14, 2013 8:59 pm
105.51 whp @ ~5800rpms
93.78 ft-lbs wheel torque @ ~4800rpms
Not sure why they didn't take it higher then 6000rpms, but I know they only ran it twice because I forgot to turn on (or tell them to turn on) the electric fans, so it got really hot & almost overheated by the end of the second run.
I haven't checked the timing in forever, or the plugs & wires, but those were replaced in 2011. She's been my daily driver since November of 2012, but I did drive her a bit during 2011. Fresh fluids in the diff, trans, & engine. New oil & fuel filter. Cleaned the Spectre air filter & oiled it. Dumped a can of Sea Foam into the crankcase and the gas tank (1/2 a can in each) and filled her up with 91 octane instead of the crappy 85 I've been running her on.
I'm sure there were a few more ponies in her if they would've pulled her all the way to 7500-8000rpms, not sure I'd get much more torque though. They didn't hook up the A/F sensor to the tail pipe or anything, so I don't have no clue what my A/F reading really is. I'm pretty sure I'm running rich, though I haven't looked into it.
Car Specs:
1985 Corolla GTS
4AGE 1.6L smallport/hi-comp from FWD GTS (90-91)
bigport intake cam (240* duration, 7.56mm lift)
smallport exhaust cam (232* duration, 7.1mm lift)
TRD .8mm head gasket
HKS valve springs
HKS adjustable cam gears
HKS timing belt
T3 underdrive water pump pulley
TRD racing header
2.25” mk III Supra Turbo catalytic converter
2.25” over differential exhaust with MagnaFlow muffler
Spectre 3” cone filter
XTD Stage 1 pressure plate & 6-puck clutch
TRD short throw shifter
Welded differential
Tokico Blues shocks/struts
Tanabe GF210 lowering springs
1985 Toyota Corolla Sport GTS - Ariel - 105.5 whp 93.8 ft-lbs of torque
2006 Toyota Tacoma SR5 V6 6MT - mmm, taco!
2006 Mitsubishi Lancer ES 5MT - 2slow
Duy-
Postby Duy- » Thu Apr 18, 2013 7:42 pm
Sorry too lazy to install the scanner, mind the fold
16v Smallport redtop
bluetop ecu and injectors
rebuilt with a trd headgasket and 3 angle valve grind
rewelded smallport intake
trd headers
toda flywheel
injen intake
fujitsubo catback
2" highflow cat
electric fan
bluetop cams
120 whp @ 6650 rpms
104 ft-lbs @ 5100 rpms
user comments: engine is mostly stock, will return for a second dyno with bigger exhaust/ smallport ecu/ and cams
20v blacktop
stock ecu
t3 velocity stacks (open stacks)
aftermarket adjustable FPR
obx stainless steel headers
no cat
obx catback
159.2 whp @ 8200 rpms
114.4 ft-lbs @ 6450 rpms
user comments: ran it pretty rich, the 20v seems to like it, saw flames out the exhaust. fuel pressure 45psi
20vmki
Postby 20vmki » Fri Apr 26, 2013 4:04 pm
20v Blacktop w/ C160 trans
Custom 2.25in exhaust
T3 velocity stacks
93 oct
Video: http://www.youtube.com/watch?v=ygYqNTUDmDI
gaijin_rokurunner
Postby gaijin_rokurunner » Mon Jul 08, 2013 1:33 pm
heres the 5.5ag dyno sheet
onnaj
Postby onnaj » Fri Jul 19, 2013 2:11 pm
This my dyno. It's a completely stock 4AGE 20V (with only open air intake) fresh rebuild eninge. Since the rebuild the engine has done about 1700 miles.
It has the Silvertop flywheel, aircon and power steering, C52 gearbox. It also has the stock 7AFE exhaust with catalytyic convertor. I'm going to change the exhaust cause by coincedence i discovered yesterday that the last exhaust part has an inside diameter of only about 1.5" (40mm). A blacktop needs 1.75" at least but is more happy with 2" or maybe max. 2.25".
I'm not really happy with the power output, but the torque curve is really nice.
EDIT: it's on RON98 (93AKI i think)
ethergore2
Postby ethergore2 » Sat May 23, 2015 5:27 pm
High comp
.5 over pistons
3 angle valve job
Bronze guides
280 Crower cams 8.3 lift
Milled head and block
TRD thin head gasket
YSPL "most badass" headers
Custom exhaust, no cat, 1 resonator, Magnaflow exhaust
HKS adjustable cam pulleys (cam timing never adjusted or degreed)
SIlvertop ITBs
T3 stacks
Fidanza flywheel
Exedy 3 puck
Light 1 piece drive shaft
VEMS Fuel management- Alpha N
91 octane gas
mustangraptor03
Postby mustangraptor03 » Thu Jun 04, 2015 9:29 am
Note: Dynapack Dyno
MegaSquirt MSPNP2 Baseline Tune (From 8/2012)
MSPNP2 with MAP conversion
K&N custom filter
Web Cams 577 Grind
HKS Valve Springs
T3 Adjustable Cam Gears
3 Angle Valve Job
Rotating Assembly balanced to 8000 RPMS
AE92 Flywheel
Electric Fan Conversion
Wiseco 81.50mm Forged Pistons
OBX 4-1 Header
Decat
Fel-Pro OEM Headgasket
APEXi 2.25" mandrel bent exhaust
93 octane fuel
97 WHP @ 7200RPM
91 lb/ft @ 4200RPM
I have since switched to using ITB mode (Speed Density and Alpha N) instead of just Speed Density and working that out until I take it back to get the tune looked over once over and smoothed out.
