Hi
hi friends, I've had a problem with the "check engine" on,
it is code 6
but in the online manuals that I find are missing the pages of how to repair that error I think it's IG-6
I wanted to know if any of you has those 6 pages to try to solve my problem
fix distributor code 6, check engine code
Re: fix distributor code 6, check engine code
Make sure to not rule out the air gap for the distributor on both rotors. Check that after doing a ohm test. Good luck!
