fuel rail and injector options and fabricator suggestions
Kuromi_loves_toyota
Postby Kuromi_loves_toyota » Sun Jan 01, 2023 11:09 pm
i got my hands on some late model TRD Atlantic throttles not too long ago, theyre pretty bare bones, just throttles with butterflies, an ive been looking for a fuel rail and some injectors, but i cant seem to find much. im also looking to get an adapter plate made to fit the throttles to my 20v, anyone have ant suggestions for these?
"be creative and live a fun life, and dont be an asshole" KB43VER
Re: fuel rail and injector options and fabricator suggestions
Postby jondee86 » Mon Jan 02, 2023 11:54 pm
Have those throttle bodies got injector bosses hiding underneath ?
Kuromi_loves_toyota
Postby Kuromi_loves_toyota » Wed Jan 04, 2023 11:07 am
yeah i have bottom feed throttles, but i didnt buy them with injectors or a fuel rail, i just got the throttle bodies.
Corey20v
Postby Corey20v » Thu Jan 05, 2023 11:01 am
Measure the inner diameter of where the injector seats to figure out which top feed injector size you need. Measure the distance between injector port centers. Now you roughly know what you need. Before buying injectors, check out the sweet youtube videos on building a custom fuel rail. There is different termination types for top feed. Decide which you think you can tackle. (Pipe w/ barb fittings exiting perpendicular; pipe with welded injector bosses exiting perpendicular etc)
Size your fittings to match the rest of your fuel system ie AFPR (AN -6, -8 etc).
Definitely not impossible, requires some tools, jigs, thinking.
1986 SR5->20V ST (WIP!)
Kuromi_loves_toyota
Postby Kuromi_loves_toyota » Fri Jan 06, 2023 2:54 am
@corey20v,
hmm, never thought of making my own fuel rail, thanks for the tip!! could you send some links to where i can find the materials?
Kuromi_loves_toyota
Postby Kuromi_loves_toyota » Fri Jan 06, 2023 3:07 am
nvm, i found some fuel rail extrusions, do you have any recomendations for size?
Davegt27
Postby Davegt27 » Sun Jan 08, 2023 2:42 pm
I bought some fuel rail blanks (not sure what you call them) from AEM like 20 years ago
Davegt27 Code One Racing
Corey20v
Postby Corey20v » Mon Jan 09, 2023 1:35 pm
Kuromi_loves_toyota wrote:nvm, i found some fuel rail extrusions, do you have any recomendations for size?
If you aren't already running an AFPR to match the fitting size from, just plan on AN -6. Way more than enough, and common sizing for AEM AFPR.
Mcmaster for raw materials, Earl's fittings.
If you need aluminum or stainless welding, you can call up performance exhaust shops and ask, some will be happy to help w small tig jobs. Places that build metal fences, fabrication services near you etc may help too.
