5.5AG build thread!
Kuromi_loves_toyota
5.5AG build thread!
thought id start a thread for my work in progress 7AG 20v, so far I've acquired a set late model Formula Atlantic throttle bodies(a friend of mine has developed an adapter for the 20v head!), VVT cam gear for the blacktop head, soon im getting my hands on some new cams! hope this build will pan out the way i want it :D
Last edited by Kuromi_loves_toyota on Fri Sep 13, 2024 12:52 pm, edited 1 time in total.
"be creative and live a fun life, and dont be an asshole" KB43VER
Re: 7AG build thread!
OH BOY!! Another 7AGE! I'll be watching this one.
I will ask why you went with the 20v head though. A lot do, but I've found the big port does as well, if not better. Having the 20v moniker is more an ego than necessity. Each to his own.
I have a couple of suggestions, right off the bat. The 4AGE oil pump and the 7AFE block oil galley interface is a tad off. Need a late 4AFE pump gasket and port match the holes or live with a restriction at the block.
And the other is to get the MRP girdle and studs. Can find it at "Battle Garage"(I'm taking for grated you reside in the U.S.A.). It's a bit pricey, but well wort it! A plus is being able to use the stamp steel 4AGE oil pan. Helps with the exhaust clearance issues under the block.
Another thing is to relocate the starter to the intake side of the engine. A 7AFE starter and backing plate do well enough, you don't NEED to source a 20v 4AGE starter and backing plate.
Just my 3 "must dos" for a 7AGE. I was able to use the stock exhaust with the steel pan and relocating the starter, I live in California and stock equipment keeps the Nazis happy.
One shot, one kill.
Really helpful advice for someone.
totta crolla wrote:Really helpful advice for someone.
Isn't that why we are here?
One shot, one kill.
With that in mind, anybody thinking of using ladder caps should consider the MRP girdle. Nice piece! Even in a 4AGE.
One shot, one kill.
Another not a fan for a 7AG 20V, the intake valves are too small, compared to a fully ported big valve largeport head.
also the TRD F/A ITBs don't require an adapter for use on a largeport head. I wouldn't want to see the air flow disruption with an adapter that goes from the long wide TRD ITB to the oddly shaped 20V port. To be honest if running the 20V head, run the 20V throttles.
Unless you're building a full race engine the 7AGE does best with a mild to moderate small port head. An all out build is better with the large port. The 20v is mostly posturing.
Either way the 7A has become my favorite overall engine for my little cars.
Eagerly waiting to see where this build goes.
One shot, one kill.
odd enough MRP chose a stock 20V head/oe cam on his 440hp 7AG beast. Hit a 'wall' with oem valvesprings iirc.
RollaChriz 550+hp street 7AG thru a stock 16V head/oe cam. So ya never know with these heads, until 'performance' tested
Obviously both boosted tho. A TON of n.a. 7AG builds documented & dyno'd on the web. Dunno how much info still up
From memory, RollaChriz did break his ladder caps... but I'd think that's a lotta stress on that poor li'l motor
Kuromi_loves_toyota
sirdeuce wrote:OH BOY!! Another 7AGE! I'll be watching this one.
no particular reason, just whats currently available to me! ill take note of the issue with the oil pump and the advice on the starter, thanks for the info
Kuromi_loves_toyota
oldeskewltoy wrote:Another not a fan for a 7AG 20V, the intake valves are too small, compared to a fully ported big valve largeport head.
yeah some friends have told me that its a bad idea, but i wanted to do something a little different, chances are ill swap back to my S/T throttles and use the FA throttles on a less serious engine.
Kuromi_loves_toyota
been slowly gathering parts..
so far i have some cams, and a whole rotating assembly. my cylinder head needs some work so im sending it into a machine shop soon. so i was thinking i might as well have my exhaust and intake ports shaved and polished too, does anyone have any advice about this? theres nothing in the TRD bible about 20v heads other than part numbers.
Kuromi_loves_toyota wrote:been slowly gathering parts..
I've been known to work 20V heads, here are 2 recent examples:
https://gallery.ostportworks.com/thumbn ... ?album=103
https://gallery.ostportworks.com/thumbn ... ?album=112
Kuromi_loves_toyota
sick! ill definitely use your work as reference material, if you dont mind could i send you a private message about a commission?
Kuromi_loves_toyota wrote:sick! ill definitely use your work as reference material, if you dont mind could i send you a private message about a commission?
sure....
Kuromi_loves_toyota
some things came up, I haven't been focusing on my engine build as much, but i have gotten some other stuff done! removed the seam sealer and stitch welded my engine bay, I also ordered a Flo's chassis reinforcement kit and I'm gonna be welding that up tomorrow! I've also got some suspension components on the way, Cusco control arms and tension rods as well as a Nagisa auto equal length 4 link kit.
furthermore, in the time I haven't been focusing on my engine, I've considered switching directions with my build, I'm currently looking into CBYs 5.5AG stroker, and if its not possible to get my hands on one of those, ill probably go with MRPs kit.
one problem with stroker kits, you tend to lose crankshaft strength because you lose journal overlap.
Kuromi_loves_toyota
ill have to do some more research on this, thank you for the information. is there anything else i should know? i still havent made the decision which route im going with my engine. my main reason for looking into a 5.5AG was maintaining a square engine and lower consecutive ratios. i want my engine to be as reliable as possible so keeping piston speeds down is one of my priorities.
Kuromi_loves_toyota
Re: 5.5AG build thread!
back at it again, got a smallport block sleeved, cleaned up and ready to be assembled as soon as my rotating assembly is delivered! so now im gonna focus a little more on the head. i originally planned on using MRPs stainless steel valves as well as their titanium retainers and toda valve springs, but ive decided to custom order some ferrea valves instead, has anyone here ordered custom valves for the 20v head? if so id greatly appreciate any advice and id love if anyone could share the specs they used.
Kuromi_loves_toyota
its been a very interesting year.
been going through some major medical issues, had to take a step back from my corolla entirely. Haven't legally been able to drive since May due to my state's laws on epilepsy and driving. I haven't been able to get much done with my engine or my car since I've been paying for more important things. I hope I can get back to this in the near future. super bummed that I basically had to abandon my project. Trying to stay positive and hope for better circumstances.
sorry to hear about your problems, hopefully the meds will allow you to get back on the road
I have a 5.5 GZE(i just say 5AG since it is easier to say, a buddy was bringing in parts off Yahoo Japan and I picked up a HKS crank for cheap
I also picked up a AE101GZE oil squirter block, picked up a Jun AE101GZE fly wheel 230mm (if I remember right)
it was one of those if I do this I might as well do that builds
got some custom 83MM pistons from Wiseco custom pistons and TRD 18mm pin Rod
so basically all the cool parts I picked up over the years and I thru them in
was a fun cool build
Good Luck
Good Luck
Davegt27 Code One Racing
Kuromi_loves_toyota
Davegt27 wrote:sorry to hear about your problems, hopefully the meds will allow you to get back on the road
Good Luck
I believe ive read a thread about your build and ive based a good amount of what i have planned off it! i planned on using a CBY crankshaft but now i plan on using a tomei crankshaft and CBY rods since CBY seems to have discontinued theirs, could you by any chance give me the specs and dimensions of your pistons? ive been having a hard time finding an affordable option.
Last edited by Kuromi_loves_toyota on Wed Nov 26, 2025 11:11 pm, edited 1 time in total.
Kuromi_loves_toyota
and thank you very much for the good wishes
I am planing on another 5.5 AG build
I already have that crank girdle and some HKS 83mm High comp pistons
just been looking for another oil squinter block
I've been recently commissioned to build a big valve 5AGTE from a smallport donor. It will be using a 1st gen HKS stroker crank, Molnar rods, custom Traum piston (10:1), and of course a OST big valve head.
1st custom made part: a sump spacer - allows use of the windage tray without contacting the crankshaft.
