20v plugs, o2 sensor
RW Bliss
Postby RW Bliss » Thu Mar 21, 2013 8:12 am
I'm finishing my 20v blacktop swap, want to know which spark plugs to use that I can cross
Reference off a car here, also O2 sensor and map sensor. I'm using dr tweak harness and COP.
Oem A/T ecu. Thanks
morgan
Re: 20v plugs, o2 sensor
Postby morgan » Fri Mar 22, 2013 9:25 am
use whatever spark plugs it says in the FSM. or i can tell you later when i get home if you dont have access to one online. as for the MAP-any 90's corolla, 4afe or 7afe motor. as for O2, buy one for an mr2 with the 3sgte motor. OBX sells one for around $60. the plug needs to be lightly modded to fit the BT harness
My turd of an 86
20v swapped 86 write-up
Stephen
Postby Stephen » Sun Mar 24, 2013 3:04 pm
I got a obx o2 sensor from eBay, mr2 turbo fitment. Quite reasonable price. The lads on here helped me sort out the wiring /depending. Works great.
greenae102
Postby greenae102 » Thu Apr 04, 2013 2:15 pm
could have used upstream O2 from 8th gen corolla (98-02) or 94-95 4 runner with v6. I have the bosch sensor on my car now p/n 13051. no wiring needed
green ae102
7ag 20v installed
my 4 door will own your 2 door!
