20v blacktop oxygen sensor
twotoedbandit
Postby twotoedbandit » Wed Feb 20, 2013 9:56 am
Been looking for a replacement o2 sensor for my blacktop. Can't seem to find a definitive answer on an available replacement. Is there a confirmed to work denso 4wire replacement I can easily order? Part no if possible for the replacement or a link. Thanks!
xb_release_2
Re: 20v blacktop oxygen sensor
Postby xb_release_2 » Wed Feb 20, 2013 4:33 pm
I don't have the part number on hand, I'll see if I still have the box when I get home. However I used a 4 wire Bosch o2 sensor from autozone and plugged right into the harness and never had a check engine light.
gaijin_rokurunner
Postby gaijin_rokurunner » Wed Feb 20, 2013 5:01 pm
not 100% sure but i think u can use the 3sgte from a mr2 turbo on the blacktop
twotoedbandit
Postby twotoedbandit » Wed Feb 20, 2013 5:56 pm
Thanks guys, I'm sure one of the universal denso or Bosch sensors will work, just wanted a confirmation from someone who has used one. The oem number doesn't give me any cross reference for cars when I google it. Xb, if you do have the box for reference that would be awesome! Any other ideas guys.
xb_release_2
Postby xb_release_2 » Wed Feb 20, 2013 10:28 pm
I think I may have cross referenced it to a turbo mr2. I'm pretty sure any 4 wire o2 sensor that will plug in will work. I believe almost all of the 4 wire heated narrowband o2 sensors work the same!
ga_goosh
Postby ga_goosh » Thu Feb 21, 2013 5:11 am
twotoedbandit wrote:Been looking for a replacement o2 sensor for my blacktop. Can't seem to find a definitive answer on an available replacement. Is there a confirmed to work denso 4wire replacement I can easily order? Part no if possible for the replacement or a link. Thanks!
I saw in another post by hasport that you can use one from a 3sge sw20 mr2. you will have to splice the plug from your 20v o2 sensor to the mr2 sensor for it to work
http://club4ag.com/forums/viewtopic.php?f=13&t=2191
if you go to oreily auto parts they sell a universal oxygen sensor that doesnt have the plug. if you cut the connector from your 20v o2 sensor and splice it to this one you will have a o2 sensor here is the link about 50 bux or so
http://www.oreillyauto.com/site/c/detail/BOS0/15728/02205.oap?year=1993&make=Toyota&model=MR2&vi=1276871&ck=Search_oxygen+sensor_1276871_1309&keyword=oxygen+sensor
I <3 my AE86
4AG Manual
AE86 FSM
twotoedbandit
Postby twotoedbandit » Thu Feb 21, 2013 12:38 pm
Awesome! Thanks guys, exactly what I was looking for!
morgan
Postby morgan » Sat Feb 23, 2013 7:16 pm
Buy an OBX 3sgte o2sensor for $60 on eBay. Go to the junk yard and snip the 4wire plugs(you need both ends) from any mid 90's Camry or other Toyota. Re-pin exactly as they are. Plug, play...
My turd of an 86
20v swapped 86 write-up
Phatman
Postby Phatman » Tue Apr 02, 2013 10:09 am
Bosch worked for me for a year then just died without warning. Maybe it was overwhelmed by the 20v's. :lol:
onnaj
Postby onnaj » Tue Apr 02, 2013 1:40 pm
Does anyobdy know of if the stock 7AFE oxygen sensor will also suit the 4AGE Blacktop?
Part number is 89465‑20520.
morgan
Postby morgan » Tue Apr 02, 2013 2:11 pm
if its a 4-wire, it should.
My turd of an 86
onnaj
Postby onnaj » Wed Apr 03, 2013 4:40 am
I think mine is 2-wired, but have to check that. I don;t have a OBD2 engine and only one oxygen sensor, so i think it's 2-wired. I think the OBD2 equipped angine had the 4-wire sensors already.
morgan
Postby morgan » Wed Apr 03, 2013 6:42 am
20v needs 4 wire
My turd of an 86
greenae102
Postby greenae102 » Thu Apr 04, 2013 2:06 pm
20v bt uses the same O2 as 8th gen corolla (98-02) and 94-95 4 runner with v6. I have the bosch sensor on my car now p/n 13051. Plugs and bolts up perfectly.
green ae102
7ag 20v installed
my 4 door will own your 2 door!
onnaj
Postby onnaj » Fri Apr 05, 2013 4:38 am
I've ordered this one:
http://www.ebay.com/itm/150826551109 (Bosch 15728 4-wire universal) For that price it couldn't hestitate to buy :D
greenae102
Postby greenae102 » Fri Apr 05, 2013 12:54 pm
hell with that wiring :D
green ae102
7ag 20v installed
onnaj
Postby onnaj » Fri Apr 05, 2013 1:05 pm
greenae102 wrote:hell with that wiring :D
no problem, still have to adapt the 4AGE harness to the 7AFE harness, so this is just a little bit extra :)
morgan
Postby morgan » Fri Apr 05, 2013 6:16 pm
Thing I don't like about them is 2 wires are same color. None of which match the harness. Good luck if its not assembled and/or labeled
My turd of an 86
greenae102
Postby greenae102 » Sat Apr 06, 2013 5:09 pm
I work at oreilly and guess what :roll: ...they're not labeled lol. No telling why tho
green ae102
7ag 20v installed
onnaj
Postby onnaj » Sat Apr 13, 2013 12:42 am
Sorry but they are lables and there's a table to compare the wires with the OEM wires. Made a picture of it!
Then you check here: http://www.padandwheels.com/mr2/blacktopproject/engharness/engharness.html. Then you check over here what colours should be matched. I think i can say this really is doable.
onnaj
Postby onnaj » Wed May 01, 2013 1:27 am
After all i have a 4-wired oxygen sensor already on my 7AFE. One of the difference with the US spec models i think. Never knew there where OBD-1 equipped 7AFE's that had 4-wired oxygen sensors.
Even my exhaust header is exactly the same size as the 20V one. Only the connection to the head is a bit different.
