Hello all! Before i get to my main question i figure i should introduce myself a little bit. My name is Colton, I live in Canada. I just recently bought myself an ae92 and i love it! its a weekend warrior type of vehicle that i only take out of special occasions.
Im looking to put some new cam shafts in to hopefully make some more power! My question is what grind would you recommend that i can still use with my stock ecu, and valve train parts? Also, would i benefit from buying adjustable cam pulleys for my new cam shafts, or just stick with the stock pulleys?
Thanks in advance for all of your help!
New cams question
MisterJerk
Re: New cams question
tomei poncams! made to be ran on stock motor.
That would be my suggestion as well. The performance is hard to beat and at the price they are even harder to beat.
http://www.matrixgarage.com/products/to ... 64-81mm-ex
You will see good gains without gears but if you get gears and put it on the dyno you will be able to move the power curve around as you like. They are not necessary with these cams though.
http://www.matrixgarage.com/products/to ... toyota-4ag
Thanks for the quick reply! Looking forward to ordering those cams next week!
