20v Blacktop Speedo Cable
Nyriks
Postby Nyriks » Sun Apr 21, 2013 12:11 am
Hi I had an issue with my speedometer not ready correctly when I still had a 16v. It was over by about 15mph. I am dropping in a 20v Blacktop right now and I was wondering what speedo cable I would need. Any one have info on what part number I will be needing?
Thanks,
Tim
LongGrain
Re: 20v Blacktop Speedo Cable
Postby LongGrain » Sun Apr 21, 2013 1:01 am
speedo cable has nothing to do with the engine, if you're using the stock T50, then the speedo cable stays the same...
morgan
Postby morgan » Sun Apr 21, 2013 8:56 pm
Means your speedo drive gear(and mating trans output shaft worm gear) don't match up with your cluster. One is sr5 other is GTS.
Or you have a 4.77 rear...
My turd of an 86
20v swapped 86 write-up
Nyriks
Postby Nyriks » Mon Apr 22, 2013 7:56 pm
Oh okay. Any info on part numbers I will need?
morgan
Postby morgan » Tue Apr 23, 2013 9:17 am
well that all depends on what you have currently. do you have a GTS gauge cluster? then i can get you the p/n's for the GTE speedo and work gear if you need those. do you have a standard 4.32 diff? i have access to oem parts need be, PM me and we can work out the specifics
My turd of an 86
morgan
Postby morgan » Thu Apr 25, 2013 9:39 am
said "diff" meant Ring & Pinion aka R&P
heres the parts you need to convert your trans to GTS gearing fro speedo in cluster.
My turd of an 86
