20v ST afm help any other car use the same afm
hachiroku ae86
Postby hachiroku ae86 » Sun May 19, 2013 9:34 am
so i picked up a 20v ST and it didnt come wit the afm so im trying to find out if there is any other toyota that uses the same afm as the ST. i was told the 1990 4cyl. camry but i want to make sure
Andrew Goodluck
email- hachitruenoae86@gmail.com
paypal- teenmob2@yahoo.com
cell- 909-697-7094
85coupe gtsr5 DDDM(dily driven drift missle)
98 ford f-150 DD blown up
morgan
Re: 20v ST afm help any other car use the same afm
Postby morgan » Tue May 21, 2013 9:11 am
ive heard the same thing
My turd of an 86
20v swapped 86 write-up
Army Fork
Postby Army Fork » Wed May 22, 2013 7:12 am
From what I've found you want the AFM from an 88-91 Camry that has the 2.0L i4 engine, the 3S-FE. Any car from that era that uses a 3S-FE should work.
1984 SR5-GTS 20V ST/BT coupe.
- Stance GR+ Coilovers
- Mishimoto Cooling
- T3 Short shift
- Manual rack conversion
- Blacktop electronics
