4age 16v (AE92) Starter Relocation
apsogosGTi
Postby apsogosGTi » Wed Aug 14, 2013 9:18 am
hello guys!how are you?
This is the time for the starter to be relocated !
i want your "Lights" here cause the guide from ae92gts website is down...
i have bought the clutch "rear end plate" from ae92 latest 4afe that has the starter hole from the intake side....
Now i dont know the exact part number the mr2 turbo 1.4kw starter (that the ae92gts website proposed)
I found by myself from toyodiy mr2 turbo 3sge starter part number 28100-74070 but i am not sure that it is compatible with my project....
some help guys!
P.S.
My 20v ST header to my 16v engine project!
http://forums.club4ag.com/zerothread?id=111598
the header from the starter has a minimum distance even with the header spacer.
toyotaspeed90
Re: 4age 16v (AE92) Starter Relocation
Postby toyotaspeed90 » Thu Aug 15, 2013 10:52 am
you can use an ae92 4afe or ae102 4/7afe starter.... same bolt pattern just a slightly lower output. I used a 4afe starter on smallport 4age's for years without issue.
taroroot
Postby taroroot » Thu Aug 15, 2013 8:35 pm
I used the 4AGZE starter. Needed to mod my coolant lines a bit. Got it from local aftermarket auto parts place, Napa I think.
apsogosGTi
Postby apsogosGTi » Thu Aug 15, 2013 11:25 pm
guys thank you for your fast answers.
The 4age 20v starter (which is a small one if i remember right) wont do the job?
Do we have some part numbers ?
p.s
You have used these starters relocated.Yes? to the intake side with an ae92 4afe rear end plate with the hole to the intake side?
apsogosGTi
Postby apsogosGTi » Fri Nov 22, 2013 7:49 am
hello guys... i have the trans out....and i am relocating the starter....the coolant pipe needs to be modified a bit...so i send it to a local machinery shop....
apsogosGTi
Postby apsogosGTi » Sun Nov 24, 2013 7:12 am
i am posting new photos from the starter relocation job and the 20v clutch flywheel installation !
Balanced
you can see the dots of balancing
the rear plate for the 4afe that i bought, as you can see has the starter hole from the intake side !
