tps help needed asap
saifmansour
Postby saifmansour » Tue Mar 25, 2014 11:31 am
hey guys i have an ae86 with 4age redtop on it. i lost my tps so i got a new one but i'm not sure if it would work properly . and can i change the wiring to make it fit on my harness ? Image the same as this one . thanks
Re: tps help needed asap
Postby totta crolla » Tue Mar 25, 2014 11:59 am
You can probably make it work by changing the wiring, it may not be ideal but probably worth a try.
Just make sure you get the wiring correct:
http://s3.amazonaws.com/2cp-images/ques ... /large.jpg
Where vcc is +5v, vta is return signal to ecu, idl is idle switch to ground and E2 is ground
