JDM GZE 14 Fault Code
Momosc
Postby Momosc » Sat Apr 19, 2014 1:17 am
Hi
My car is a 1987 AW11 with JDM 4A-GZE (Levin) swap done way back in '98. Ignition is twin coil distributorless. Harness, ECU from Levin.
Won't idle. Runs well under load, but even then I'll get the occasional stumble and check engine light, which then turns back off. From cold start, it'll idle at about 2000rpm, stumble, throw a check engine light and stall.
Fault code shows 14. Replaced igniter. No change in symptoms.
Ideas?
Thanks, Mo
