Currently running a ae101 block with a jdm Hi comp head.
I'm trying to get my PS working in my AE86
Anyone know what bracket I need? I think the one on it might be for FWD or Mr2?
Also what belt should i run? (no ac)
Thnx
![Image](http://img.photobucket.com/albums/v705/igotrice87/hachimon/hachi%20motor%20swap%20jdm%20hi%20comp/91d5add0-f58c-4468-af46-128655c60ee9_zps739bb28f.jpg)
JyuRoku wrote:I know for my swap, we had to use the 16v crank pully with 3mm shaved off the mounting surface. Then used all the 16v accessories, including the waterpump.
phanist wrote:if you are using the ae86 16v PS pump and bracket it should line up with your 16v crank. unless that crank pulley is from the ae101 block it maybe different deep.
trying using all the crank ,bracket etc from the same block..... or maybe your idler pulley is not bolt down correctly ....if your PS pump pulley line up with your crank pulley then why not the idler pulley? it attach to the PS bracket noooo?
i think you have to use the same bracket from that accessory
phanist wrote:Reading his post a couple post up. He say that the ps pump pulley and crank pulley line up but the idle pulley on the ps pump bracket doesnt... That a bit weird.. There have to be some thing wrong about that idle pulley. Maybe it not bolt in correctly... ? From my understanding that idle pulley is there to guide the belt and tension of belt? So if the whole ps pump assembly work correctly together is should line up at least pump pulley and the idler should line up correctly but not the crank pulley... Maybe the OP have it mix up... The pump and idler line up but not the crank.... And way...
There seem to be missing some picture of the actual situation. Would help...
How is your altinator and crank? Are they line up? So exactly line up and what does'nt?
