Trying to figure this out on my own, I hijacked a picture from google to find out what all needs to be eliminated, bypassed, or rigged up with the new throttle body install. I am aware that the pipe after the throttle body must be ground out to accommodate the larger butterfly during WOT and there will be issues with cold starting, and the TPS should be rotated 180* then adjusted accordingly for idle, AND I SHOULD make a PCV catch can system into the the new intake piping (replacing the J-pipe).
First off, I have no idea what this sensor is for, can anyone tell me?? It is marked in yellow.
Second, when eliminating the J-pipe (before throttle body) can I just block off all the vacuum lines going to it or do they need to be rigged into the intake? (A/C VSV, Air control valve, etc)
Third, on 4AG T/B I'm planning on connecting the power steering vacuum lines and TPS sensor but blocking off everything else. I'm not sure what these 4 vacuum lines are for on the back side, can I just keep these blocked off?? Should I connect the A/C VSV from where it went to the J-Pipe on 4agze?
