agze oil sump replacement
Posted: Sun Jun 01, 2014 1:02 pm
by xarion
HI Guys
I am going to be replacing my oil sump. How do you remove all oil residue from the block and gasket so that the sealant can stick ?
Thanks!
Xarion
Re: agze oil sump replacement
Posted: Sun Jun 01, 2014 2:30 pm
by jondee86
A can of spray-on engine degreaser ?
Posted: Sun Jun 01, 2014 5:12 pm
by MisterJerk
there isn't a paper gasket between the oil pan and block. fipg from the factory.
hopefully you have the engine out. I used half a roll of paper towels and some carb cleaner.
Posted: Sun Jun 01, 2014 9:19 pm
by xarion
Thanks, thought that degreaser might still leave a little bit behind, thanks =)
Posted: Wed Jun 04, 2014 7:26 am
by s24a
If you are worried about degreaser residue, then go over the sealing areas with a cloth soaked in Brake Cleaner (or use Acetone).
This will clean and dry the surfaces for the FIPG material.
Posted: Thu Jun 05, 2014 4:49 am
by xarion
Thanks for the advice, will give that a try!
