T3 crank pulley for 20V question
The Bloody Panda
Postby The Bloody Panda » Thu Jul 03, 2014 11:00 am
I've got a T3 single row crank pulley for my 20V Silvertop. Can anyone tell me why there are two timing marks cut into it?
morgan
Re: T3 crank pulley for 20V question
Postby morgan » Thu Jul 03, 2014 12:14 pm
I believe the outer most one is for use on a 4agze, while the standard one is the 4age.
My turd of an 86
20v swapped 86 write-up
morgan
Postby morgan » Thu Jul 03, 2014 12:20 pm
My turd of an 86
Postby yoshimitsuspeed » Fri Jul 04, 2014 1:05 am
I think Morgan is close but I think it's more application specific.
For example the AW11 uses a timing pointer coming off the timing belt tensioner bolt which sits at approx 10 o clock. The timing pointer points to a mark in between the two stock pulleys which would be the outer face here Other motors like the 20vs use numbers printed on the timing cover with TDC being closer to 2 o clock. On these motors the timing mark is on the innermost face of the pulley.
morgan
Postby morgan » Fri Jul 04, 2014 5:38 am
Exactly, thats what the second pic shows. The difference between setting timing between an AE and an AW chassis, and their respective notch locations on the pulley
My turd of an 86
The Bloody Panda
Postby The Bloody Panda » Fri Jul 04, 2014 6:06 am
Yup, you are both correct. I have now verified that number 1 cylinder is at TDC when the innermost timing mark is exactly at zero degrees. Thank you for clearing that up for me.
ticotek
Postby ticotek » Fri Jul 11, 2014 5:27 pm
Hey, how is that working out for you? I always wanted a pulley but afraid it will throw off the balance and mess it all up.
The Bloody Panda
Postby The Bloody Panda » Fri Jul 11, 2014 6:14 pm
I never actually ran the engine with the factory pulley so I can't compare the two. I personally won't run a crank pulley that isn't lightweight since I haven't experienced any problems with it. There was a company though that was selling balanced lightweight crank pulleys for the 20V, but I can't remember who they were. I'm pretty sure I bookmarked it though so I'll look through my links and see if I can find them.
I could just be unaware of my stuff being out of balance though, I've got an aftermarket flywheel as well and I recall someone on here saying those things are rarely balanced. I figure that would be a bigger concern since those are so much heavier than a crank pulley. But I'm a sucker for weight reduction, especially on anything that rotates.
The Bloody Panda
Postby The Bloody Panda » Sun Jul 13, 2014 7:16 am
Can't find that link for the 20V balanced lightweight pulley that I was thinking of. I think it was pass racing or paradise racing that was selling it. I found out that a lot of my old bookmarks go no where now. I saw that pulley like 3 years ago so maybe it doesn't exist anymore.
onnaj
Postby onnaj » Sun Jul 13, 2014 8:04 am
The Bloody Panda
Postby The Bloody Panda » Sun Jul 13, 2014 2:45 pm
Dang there's some nice stuff on that website. The pulley I was thinking of looked different than that one but that one looks higher quality. Quite the price tag as well.
ticotek
Postby ticotek » Mon Jul 14, 2014 9:17 am
Yeah... I've seen theirs and its nice... but thought of T3 (price), was just concern about the balancing.
The Bloody Panda
Postby The Bloody Panda » Mon Jul 14, 2014 9:26 am
Here's an interesting link about lightweight crank pulleys versus the factory crank pulley on a 4age.
http://www.86garage.com/forums/viewtopic.php?t=848
ticotek
Postby ticotek » Mon Jul 14, 2014 12:14 pm
Man... great link!!!
