It is my first time and I want to know if this how a BT 20V 4age drives like:
It's done and there's no codes, all parts replaced with either OEM or AISIN...Everything is pretty much new, timing is correct, and adjusted ITB to spec. Took it for more spin and it drives fine on normal daily or freeway, but when WOT it doesn't go anywhere..Just loud ITBs and doesn't pick up until past 4k rpm...It is like a flat spot between 2-3k rpm. ECU is good and all voltages/ohms to each sensors are withing spec, no bogs, no backfires...
BT 20V swat complete but weak?
Re: BT 20V swat complete but weak?
VVT solenoid
My turd of an 86
20v swapped 86 write-up
My turd of an 86
Stacks could kill torque a lot, depending also on the lenght of the stacks.
sprinterr86
torque? its a corolla.. LOL
...the little that you have. lol
My turd of an 86
My turd of an 86
sprinterr86
i will be running 120mm stacks, planning on buying those T3 air filters, but im looking for alternatives.
sprinterr86
webyosan wrote:It is my first time and I want to know if this how a BT 20V 4age drives like:
have u done any minor tune up? spark plugs? wires? and also wut kind of fuel pump are u using? wut gas are u using? u can start trouble shooting and check off variables off the list. worst comes to worst, the motor u got is tired.
Compression test? Leak down?
Everything asked so far is good advise. I'd pay attention to the VVT solenoid.
Pursuing the ideal
sprinterr86 wrote:i will be running 120mm stacks, planning on buying those T3 air filters, but im looking for alternatives.
That should be a good length for torque!
I'd also say measure the resistance of the oil control valve and do a complete checkup of the distributor cap, rotor, plugs, plug wires, etc. Plug wires should have no more then 25Ohm (from my head). But if you use google and search for the 4age blacktop manual you'll find some links to the manual.
