If you NEED to comment... PLEASE go here - viewtopic.php?f=13&t=1336
This thread is for build information backed up with dyno results ONLY.
4AGE, N/A, on stock AFM based engine management: #s measured @ the wheels
Engine model and generation:
4AGE - TVIS head/Silvertop block
Top End Modifications:
large port head - bowls/seats ported(no other porting), pinned and port matched intake/TVIS/head, Web 294 cams, AEM camgears(intake advanced 3 degrees), RC 225cc injectors
Bottom end modifications:
20V silvertop stock except 16V OEM high compression pistons(10.3 to 1)
Management:
factory ECU
Fuel used
89+
Intake:
K&N FIPK
Exhaust:
KBD header, Fujitsubo LegalisR large muffler twintip
Driveline:
Silvertop flywheel
OEM AE92 disc and pressure plate
Other Info
The above dyno run was done with a tired 20 year old fuel pump!
