4 age carbed small port RPM'S
ktm
Postby ktm » Thu Sep 25, 2014 5:42 pm
I have a 4AGE small port 16v engine with a single 44 webber and a header. This engine is in an off road buggy,I was wondering what RPM'S you have at cruising speed. The car performs well above 2500 rpm's and runs strong to over 6000. I will often run it at 4500 to 5500 for long periods of time. I was hopping to compare my RPM to that of what others are turning in daily drivers or modified. Thanks in advance.
Re: 4 age carbed small port RPM'S
Postby MisterJerk » Fri Sep 26, 2014 6:24 am
Cruising speed?
around 3000 @ 55 mph(3000 rpm lean spot/stumble is probably to get better emissions results or fuel economy)
4500 at 80mph. Stock T50, stock 4.3 rear end.
